water coming through door
Old Feb 6, 2010 | 10:23 AM
jstforme's Avatar
Registered User
whenever it rains im getting water coming through the speaker mesh a small puddle sitting on that litte ledge right below the speaker. the speaker also gets wet so in turn it sucks to listen to music when it rains. its only on passenger side. before i take the panel off, what should i be looking for? i understand there is a rain drainage "lane" or something for water to exit under the door. i suppose its coming through somewhere around the side mirror. thanks
i did have new speakers installed but that was over a year ago, this problem has only been going on for about 4 months or so. plus like i said its only passenger side
Old Feb 6, 2010 | 12:38 PM
civicdrivr's Avatar
Theres weather stripping around the window. Its called the run channel. Theres also a strip along the bottom of the window. Look at those.
Old Feb 15, 2010 | 04:24 PM
MIKE8898's Avatar
Bonki Ehrite!
Check all of the seals on the door for holes or slits. If you find any then they could be the source. It cant hurt to replace the gaskets if they are damaged.
Old Feb 19, 2010 | 08:10 AM
NSXNEXT's Avatar
Remove the inner door panel then have someone with a hose (no spray nozzle) run water around the window and see where it's coming in.
Look at the bottom of the door panel. There are several slits that allow water to run out. Make sure they are cleared.
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
govtcheez
Oct 1, 2015 12:21 AM
theinsvnity
Sep 10, 2015 10:22 PM
eastcoastguy
Sep 9, 2015 09:59 PM
