Unknown problem?
Old Jun 30, 2009 | 12:06 AM
VIPCLS's Avatar
P.
Unknown problem?
Just recently, I have just started to notice that when I come to a complete stop, and I begin to proceed the exclamation point lights up and i hear the ABS humming sound? Do I have a problem? I read some other threads and they didn't really seem to have the exact problem. Any input is greatly appreciated.
Old Jun 30, 2009 | 01:49 PM
NSXNEXT's Avatar
Bald tires? The exclamation point is the VSA kicking in.
Old Jun 30, 2009 | 04:02 PM
VIPCLS's Avatar
P.
Naw man thats not it, i just had new tires put on her?? It makes the sound of the ABS pump sound when you first start driving, that what I learned from this site. But.. the exclamation point comes on???? You think I am harming something.
Old Jun 30, 2009 | 04:18 PM
AnthraciteBeast's Avatar
Theres was another guy on here that had the same problem, i dont think he ever posted whether or not he fixed it. I'll look for the thread
Old Jun 30, 2009 | 05:02 PM
1hotcls6's Avatar
You might have low VSA fluid
Old Jul 1, 2009 | 12:02 AM
VIPCLS's Avatar
P.
I didn't even know there was such a thing. Where is the resivor located? And anthracitebeast that thread would be appreciated if you can get the link. Thanks for the inputs.
Old Jul 3, 2009 | 08:49 PM
VIPCLS's Avatar
P.
This problem seems to just happen now and then? What you guys think?
Old Jul 5, 2009 | 02:26 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
faulty abs sensor possibly. or something to do with the VSA is intermitent... VSA works with the abs to gain control of the car so they both can affect one another. the beginning 2 times the ABS does it's thing it's checking to see everything works..
Sounds like the car keeps forgetting the abs is functioning right or wrong which is why u here it come on now and then intermittently
Old Jul 5, 2009 | 10:15 PM
VIPCLS's Avatar
P.
Hopefully whatever it is will not be a costly fix, or will even quit. Cause, like today it didn't even do it???
Old Jul 25, 2009 | 01:57 PM
VIPCLS's Avatar
P.
Allright, it seems this is only happening on like mild slopes, and sometimes right when i put the vehicle in drive? Again, it seems to be makeing the humming sound when the abs check occur's? Im thinking also that maby the a/c engageing has something to do with it? Any thoughts? Should i get it checked out?
Old Jul 25, 2009 | 04:35 PM
Honestly if anything it's just a sensor working overtime because of some malfunction. But as for driveability there shouldn't be anything to worry about
Old Jul 25, 2009 | 05:01 PM
VIPCLS's Avatar
P.
Cool, thats what I wanted to hear! It was jus worrying me.
Old Aug 9, 2009 | 07:26 PM
celynka's Avatar
Sundance Gold in
mostlikely Abs sensor giving up on you or gyro sensor
Old Aug 10, 2009 | 01:28 AM
VIPCLS's Avatar
P.
Really...Is the sensors a expensive repair? What is a gyro sensor? Should I get the sensors replaced asap, or can it wait?
Old Aug 14, 2009 | 12:35 AM
celynka's Avatar
Sundance Gold in
Abs sensors are fairly cheap and pretty easy to replace, Gyroscope sensor (main component of VSA system) is expensive - over $300 - but also easy to replace, it is sitting behind rear seat bench passanger site - just in the corner. I would drive with it till problem becomes permanent - pinpointing intermittent electrical problems is very hard, unless it leaves trouble code on ECM. One more thing - sometimes broken cv boot grease gets over ABS sensor and cause it to misread. Check your boots if they are not broken!
Old Aug 14, 2009 | 02:33 PM
VIPCLS's Avatar
P.
Finally!! I get a answer!! Thanks alot for your educated guess to what it could be. I bet it is one of the two things you mentioned, and am going to wait it out to see what it could be. I will post my update if I end up having a problem.
Old Oct 29, 2009 | 12:23 AM
VIPCLS's Avatar
P.
So I went to a certified import repair shop, and the (!) light never flashed or even came on the whole time the mechanic was in the car. The car was diagnosed and checked out fine. Mechanic said don't even worry until the problem become's permanent. Any thought's as to what this might be, CL owners? All thought's are greatly appreciated.
Old Oct 29, 2009 | 12:34 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
I would make sure you check all your fluids, if its an ! isn't that your brake light? if not I could be wrong ( I have a 6-speed, no VSA) but if it is for your brakes or something it could just be low brake fluid.
Old Oct 29, 2009 | 02:33 PM
VIPCLS's Avatar
P.
The (!) only comes on when the VSA is disengaged and if the wheel's slip while the VSA is on. All fluids are fine. The sound im hearing is the ABS pump hum, and the (!) lights up intermittently?
Old Nov 1, 2009 | 01:46 PM
VIPCLS's Avatar
P.
Any luck on that thread?
Old Nov 1, 2009 | 09:00 PM
Rajca's Avatar
wham bam thank you ma'am
wheel speed sensor. thats what was happening to my tl-p(but throwing tcs and abs lights every time from a stop.) someone cut the wires but partially. so check that at all 4 corners
Old Nov 2, 2009 | 02:10 PM
VIPCLS's Avatar
P.
That's the same thing the mechanic said on the test drive. But the high tech onboard computer showed everything good. Where exactly are the wheel speed sensors? I will check them. On the side note, I just recently got new tires installed, and if I remember correctly it started after I had them mounted and balanced with nitrogen.
Old Nov 2, 2009 | 09:17 PM
celynka's Avatar
Sundance Gold in
[QUOTE=VIPCLS;11457060]That's the same thing the mechanic said%2
Old Nov 3, 2009 | 10:52 PM
VIPCLS's Avatar
P.
It seems to have quit!
Old Nov 4, 2009 | 09:41 AM
celynka's Avatar
Sundance Gold in
Got you Abs + VSA permanently lit? It has to be ABS sensor ( or wheel speed sensor - whatever you want to call it, its the same thing)
Old Nov 8, 2009 | 04:39 PM
VIPCLS's Avatar
P.
Where are they located at?
Old Nov 8, 2009 | 06:25 PM
celynka's Avatar
Sundance Gold in
Look for it behind outer CV joint ( front ) - just follow the wire that is attached to upper control arm - and rear part of wheel hub assembly (rear )
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
