turn signals not blinking
Old Nov 9, 2011 | 08:55 PM
riuhasz's Avatar
When I go to use my turn signals they are only clicking once than stop clicking or blinking
Old Nov 10, 2011 | 10:17 AM
civicdrivr's Avatar
Check the relay.
Old Nov 21, 2011 | 01:23 PM
celynka's Avatar
Sundance Gold in
flasher relay stuck. replace it
Old Jan 17, 2012 | 12:16 PM
dcguy's Avatar
New to posting, so let me know if this is no relevance. I have similar issue. My front passenger turn signal will flash with the blinker, but when I turn on the headlights, it does not remain lit. I am going to install LED bulbs, with resistors, this weekend. Will this fix my problem?
Old Jan 17, 2012 | 03:22 PM
civicdrivr's Avatar
The turn signals are dual filament, sounds like one of them burnt out. New bulbs should fix it.
Old Jan 17, 2012 | 06:57 PM
dcguy's Avatar
Sweet, i'll find out this weekend. Thanks for the help.
Old Jan 21, 2012 | 06:27 PM
dcguy's Avatar
So I installed 1157 LED bulbs, the resistors stopped the hyperflashing, but the bulbs only light up when the blinker is on. Does this mean the bulbs I bought are only single filament and I need to look for a dual filament LED like you mentioned? I didn't see any threads on 2gen turn signal numbers.
Old Jan 21, 2012 | 07:02 PM
civicdrivr's Avatar
That could be the case. Check the base on the LEDs, which do they closely resemble:
or
Old Jan 22, 2012 | 11:31 AM
dcguy's Avatar
It looks like the bottom one
Old Jan 23, 2012 | 01:16 PM
civicdrivr's Avatar
Then they should have both filaments.
Old Jan 24, 2012 | 02:05 PM
aznboi2424's Avatar
try flipping the bulb?
Old Jan 25, 2012 | 06:36 AM
dcguy's Avatar
I bought cheap bulbs, and one of them broke as I tried to install. I ordered new ones and I will try that out if they do not stay on. I appreciate the help.
Old Jan 28, 2012 | 03:45 PM
dcguy's Avatar
The bulb needs to be rotated, but I can't because the pegs are offset? So when I stick the bulb in the wrong way, it blinks correctly, but it will not stay in the housing because both pegs are not engaged. Any ideas? Could the wiring be reversed
Old Jan 28, 2012 | 03:54 PM
typeR's Avatar
sounds like you need blinker fluid ... just go to your local auto parts store and ask for it ... if they give you a hard time tell them you are on acurazine and they know for sure thats what it is ... the resevoir is in the engine bay but onlu use the one with honda additive no synthetic !
Old Jan 29, 2012 | 10:28 AM
civicdrivr's Avatar
Where did you get them?
Old Jan 29, 2012 | 10:58 AM
dcguy's Avatar
autolumination
Old Jan 29, 2012 | 11:08 AM
civicdrivr's Avatar
Contact them and tell them what you are going through. They may have a different bulb for this, or your bulbs may be defective.
Old Jan 30, 2012 | 07:28 PM
Bazla's Avatar
2013 Infiniti G37S
I also have a similar problem. My turn signals dont come on and neither does it when I use the hazards. The is no clicking either. I checked the fuse and power to the fuse and both were good. I was curious if one bulb goes out does all the lights go out? Does anyone have an electrical print for this?
Old Jan 31, 2012 | 11:12 AM
civicdrivr's Avatar
Did you check the blinker relay?
Old Jan 31, 2012 | 11:17 AM
Bazla's Avatar
2013 Infiniti G37S
I did not check the blinker relay but I took a break to get a snack and when I came back the lights were on blinking. I will check the blinker relay next time the problem comes back. Is the blinker relay the same relay that works with the hazard? I guess the hazard just puts on both blinkers as opposed to one with the blinker. Thanks.
pplcrew
Jan 30, 2021 08:59 AM
Ty-Sama
Sep 21, 2015 05:45 AM
Sep 17, 2015 09:01 PM
Greengecko
Sep 16, 2015 08:19 PM
JnC
Sep 11, 2015 06:06 AM
