Transmission or not??
Old Mar 23, 2009 | 11:09 AM
angeloCL's Avatar
4th Gear
or
Need help trying to figure out this problem
Tranny was replaced from the dealer around 80k miles. Before I purchased the car. CL now has 103k... I took it to the dealer for inspection and they informed me warranty for that has expired.
With that being said there is a problem with the car with it sometimes not turning on properly. Once the starter kicks in the car somewhat jerks before it turns on and the rpms get really low...my car starts to vibrate really badly for a few seconds and it goes away once I drive away slowly. But sometimes my car will not start at all. I have changed the spark plugs before... battery is a month old... starter is not knocking or anything.
I know for a fact my front motor mount needs to be replaced because I have confirmed that with a mechanic... any ideas or suggestions would be helpful.
Old Mar 23, 2009 | 04:48 PM
aznboi2424's Avatar
I would say that the problem is not connected to your transmission.
Old Mar 23, 2009 | 06:12 PM
phee's Avatar
I got the Shifts
you need new plugs and a valve adjustment
Old Mar 23, 2009 | 06:13 PM
phee's Avatar
I got the Shifts
maybe IAC is bad
Old Mar 23, 2009 | 10:49 PM
thevikas87's Avatar
Your mom is in
I have the same problem, and have been ignoring it for the past year and a half, some ppl here say i need a new fuel pump...i would be really interested in knowing what the problem is as well...
Old Mar 24, 2009 | 05:36 PM
thevikas87's Avatar
Your mom is in
anyone?
Old Mar 25, 2009 | 10:38 AM
angeloCL's Avatar
4th Gear
I havent done a valve adjustment but spark plugs, timing belt, and water pump have all been changed recently and it still happens.
Oh I also changed the Idle intake value. I have a feeling now that it has to do with carbon build up and may need to really get in the upper and lower intake manifold with some carb cleaner.
Old Mar 25, 2009 | 11:15 AM
Yumcha's Avatar
Moved to appropriate forum...
Doesn't sound like a tranny problem...but, then again, I'm no car expert in regards to the mechanics.
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
