Time to fix
Time to fix
So long story short.... I missed shifted and over revved my cls6 two years ago! I have been driving around with the cel on! It idles fine but gets horrible gas mileage! I'm 300 bucks short of paying it off! I scanned the code and it's say misfire on all cylinders! I have replaced the coil packs and spark plugs! But still cel! Also took it to Acura and they said timing is spot on? There's no possible way I bent all the valves and its idling fine and still running for two years is there? Any ways it's time to fix it, I'm scared to rebuild the heads and it doesn't fix the problem would y'all suggest starting somewhere else? I just want my car running normal again problem free! Thanks
What most people on here are going to say is grab a low-mileage J35A3 and drop it right in afte swapping camshafts. Change the clutch and all seals that are easy to get to and you'll have a reliable engine that drives just as well-behaved as the J32A2 but with gobs more torque.
03 tls nc (06-02-2016)
6mt swapped..smart
Speaking from experience here. You bent all your exhaust valves. Options are to either replace the engine or the heads. You could replace all the exhaust valves on your current heads, but for the same price after parts/machine work..better off buying another set of heads.
A compression test will reflect this. PSI per cylinder should be 190-210psi. You're probably currently looking at 100-140psi/cyl. Rent a compression tester from your local auto parts store and report back
I'm 98% sure it's the valves just want to make sure I'm not over looking anything thanks
teh CL (06-03-2016)
6mt swapped..smart
teh CL (06-03-2016)
guyenacurazine
06-18-2016 03:56 AM
danperson1
01-26-2016 03:33 PM
