Throttle body spacer?
Old Aug 30, 2009 | 09:20 AM
hermtm2's Avatar
Hello.
I was looking for the T/B gasket on the web. The space was on the OEM catalog. However I don't think mine (01 CL) have it between T/B and intake manifolder. What does the throttle body spacer do?
Thanks.
Old Aug 31, 2009 | 01:54 AM
aznboi2424's Avatar
are you talking about an aftermarket TB spacer or OEM spacer?
Old Aug 31, 2009 | 03:15 AM
civicdrivr's Avatar
If hes talking about the OEM parts diagrams, he may be getting confused with the VSA body and the throttle body. But his 01 should have that.
Old Aug 31, 2009 | 03:55 AM
jl03CLS's Avatar
6speed
the throttle body should have a stock paper gasket in between it and the im. if thats what you are talking about. it looks green and is really thin. doesnt really do much in my opinion except for cause alot of pains when seperating the tb from the im. mine got stuck to both the im and the tb and i had to use a screwdriver to seperate the two. maybe if anything it would hinder heat transfer slightly?
Old Aug 31, 2009 | 10:25 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
lol.. when i did my P2R tb spacer I only got one thermo gasket. So I just got rid of the original gasket, put in the thermo between the Im and TB spacer, and on the other side it's tb spacer to TB, and it sealed up noooo problem.
Old Aug 31, 2009 | 10:37 AM
hermtm2's Avatar
I am talking about the OEM spacer. Do I have it? I cleaned the intake manifold up a week ago but there was not spacer between T/B and manifold. Anyway what is the benefits of aftermarket spacer?
Thanks.
Old Aug 31, 2009 | 05:37 PM
tb spacer increases air volume going into ur manifold and decreases intake temperatures.
Old Aug 31, 2009 | 06:21 PM
there is not tb spacer on the car stock, it's just a paper thin gasket.
A tb spacer reduces intake temps and then u got thermo gaskets to create a heat transfer barrier if u will. and it increases volume slightly, so it will give u something for sure.
Old Aug 31, 2009 | 06:29 PM
hermtm2's Avatar
Here is what I am talking about. Look at #8.
Old Aug 31, 2009 | 07:29 PM
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I bought a TB and IM manifold spacer from outlaw engineering..
http://www.outlawengineering.com/hondajframe.html
I also cleaned out my IM while installing.. Car did respond better after instalation but not sure if it was from the spacers or cleaning all the crap outta my EGR port and Intake manifold!
Old Sep 1, 2009 | 05:19 PM
civicdrivr's Avatar
Huh.
I dont think Ive ever seen the spacer in any diagrams. Its a good possibilty that whatever site you got the diagram from screwed up. I ran a search on the PN and it came up for the Odyssey.
Old Sep 7, 2009 | 09:55 AM
poisx7's Avatar
Huh.
have to agree
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
