SIRSIG Jerking...
#81
Blown is Best
Originally Posted by SIRSIG
aaahhhh those sleepless nights ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
yeah, Shawn said it's rare to see E-manage not holding up the map, but i guess J32A2 ECU's seeing that differently. The voltage for some reason jumped and changed the values instead of zero it's reading 2V underload @ 5psi or something and that make's it lean (misfire?) so when 5psi comes it abrupt the power. not sure how to elimate this kind of problem in the future
hopefully it's isollated...
basically, if you can get the map from your tuner, you can import that to your E-manage again, if ever it's acting up. But ofcourse if you added mods it has to be tune again...Unfortunely in my case I have a different cable port on my laptop and i don't have the upgraded version of the Greedy E-manage that's why i went to the tuner...![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
#82
Originally Posted by Allout
I haven't invested in the E-Manage tuning software and cable yet. My laptop only has USB and no serial port too. I've seen USB to Serial cables around and was thinking about giving that a shot.
#83
Blown is Best
Originally Posted by NVA-AV6
As long as you are running Windows XP that will work, just let the USB-Serial driver load first.
#85
Originally Posted by New Image
Good to hear you fixed it. I have the exact same problem as you, but I dont have an emanage. So where the could the problem be with my issue?
#86
Blown is Best
Originally Posted by mrsteve
Already answered in your thread. It's the voltage clamp. It's either improperly installed or not set to the correct voltage.
#88
THE J35A2...
sweet, ill check my voltage first thing in the morning
i think 2.93v is about right on your ESM, so i dont think it's your ESM. check your TPS and other sensor, see if they're plugged-in wrong. Coilpacks are known to go bad. you can check them by unplugging the connection while the engine is running. Adjusting the valves aren't hard but time consuming, just make sure do not over tighten it. I'm pretty sure you know some of what i'm talking about...
#89
first off, you have to fixed the misfiring problem first before you install the SC
GrandeInter10
11-20-2011 02:03 AM
