Short "ram" intake systems...
Old Feb 24, 2011 | 09:19 AM
dbramaged's Avatar
I picked one up for cheap, but it makes this loud humming noise almost like a hornets nest is under my hood.. You can hear it from a good block away at an idle. When I remove the filter and mess with the air flow it will get quieter when I restrict the air flow. Has anyone else experienced this?
When I rev the engine, up to about 3-4k, and let off, it actually sounds like a recycling blow off valve. And during acceleration, the intake is louder than most fart cannons.
Also, can you reroute the coolant line for the throttle body to stay behind the intake or is there a reason why it is ran around the front with the air line to the valve cover and then back under the TB?
Old Feb 24, 2011 | 02:43 PM
dbramaged's Avatar
Ok, are any of your CAI making a similar noise?
Old Feb 24, 2011 | 03:11 PM
StreetKA's Avatar
short ram is louder and safer i think i will cut my CAI just to try it out with CAI its pain in the ass for me to check the filter every 5k miles or so
Old Feb 24, 2011 | 03:38 PM
aznboi2424's Avatar
CAI is quieter and icebox is the quietest besides stock. short ram is the loudest.
Old Feb 24, 2011 | 03:43 PM
dbramaged's Avatar
but the humming is what I'm concerned about. I figured under WOT the SRI would be loud, but at an idle it is extremely loud, at a very concerning level.
Old Feb 24, 2011 | 04:13 PM
Rapture's Avatar
I'm sure I don't have to ask this, but have you tried putting the stock intake back in and hearing if it still makes extraneous noise? Are your idle RPMs normal?
Old Feb 24, 2011 | 05:51 PM
civicdrivr's Avatar
Normal. Any open element intake on this car will hum at idle.
Old Feb 24, 2011 | 11:24 PM
dbramaged's Avatar
Stock intake is back in and the noise is gone for the most part. The resonator has been removed so there's a little more hum, but nothing like what the sri is like. The company its sending another pipe but I'm getting an extension made saturday to make it a cai for now.
Thanks civic.
Old Feb 25, 2011 | 06:53 AM
joyfil2001's Avatar
When I removed my resonator the humming was pretty loud at idle. I now switched to an AEM CAI and couldn't be happier. NO humming. Sounds great when you get on it.
Old Dec 6, 2011 | 12:44 PM
Bonez21's Avatar
I also have this problem and I'm trying to get rid of it. I may try to convert my short ram back into a Cold Air and see how that goes....
Is anyone running the intake resonator with a short Ram? I'm guessing maybe it would cut down on some of the noise?
Old Dec 6, 2011 | 01:57 PM
aznboi2424's Avatar
Can't run the stock intake resonator with any kind of intake system. Simply won't fit.
Old Dec 15, 2011 | 09:14 PM
01 cl type s a few xtras's Avatar
3rd Gear
i have the same resonating sound and all. Its normal. I took my car to the local honda-acura dealer and was told this is perfectly normal. The local (hop-up) garage said the same.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
ceb
ILX
Sep 27, 2015 10:56 AM
