Slightly kick
Old Dec 14, 2011 | 08:50 PM
99TLhot's Avatar
Slightly kick
H!i i Got an 03 CL-s 74,000k mile and it happen to me 99 TL too with over 200,000k miles , my question is that while im driving on the hight way if i lightly press on the gas there is a slightly kick is that normal?
and also my purge value is clicking kind of loud when the engine warn should i change it? and what is the little green cap next to the purge vaule say service port what is that? if got any ideal tip and how to fix my lilttle concern please help me thanks you....
Old Dec 15, 2011 | 10:16 AM
Project_CLean's Avatar
MMkay.
wrong forum dude. that "kick back" might be a trans problem though;
Old Dec 15, 2011 | 02:40 PM
aznboi2424's Avatar
Are you pressing on the gas after taking your foot off the pedal? If so, its normal. Probably has to do with the torque converter hooking back up with the trans or something like that.
As for the purge valve, you can replace it if you want but its only ticking. Nothing else will improve if you change it. Also make sure it's not your valves ticking. Not sure what the service port is for, probably the EVAC system.
Old Dec 15, 2011 | 06:19 PM
99TLhot's Avatar
yep i press the gas after taking my foot off the pedal... no the car run great no hard shift thru gear at all....
Old Dec 15, 2011 | 09:08 PM
01 cl type s a few xtras's Avatar
3rd Gear
the 2nd gen cl had a lot of trans recalls, and issues.
Old Dec 17, 2011 | 07:18 PM
99TLhot's Avatar
yep and 01-03 TL too but so far so good
hashbrown
Feb 18, 2022 11:20 AM
emailnatec
29
Sep 28, 2018 04:27 PM
joflewbyu2
Oct 8, 2015 11:16 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
CWOVette
1/2G MDX (2001-2013)
Sep 27, 2015 02:29 AM
