Is my clutch blown? *HELP*
Old Sep 7, 2011 | 02:36 PM
azeezp13's Avatar
shifting at 7k
Ok so last night I'm driving to work as usual everything is fine. In the morning when I'm leaving I got the car started and into gear, however the RPM's were fluctuating and abnormally high and there was barely any power in the acceleration. So after I got off the highway and came to a light, kicked it in neutral, from there the entire gear box locked up and I couldn't shift into any gears.
When the car is off, I can switch into gears but when it's on it won't. The clutch pedal feels a little stiff too. I'm just surprised because the clutch was replaced less than 5 K ago (last year). How could it have burned out this fast? The clutch showed no signs of slipping and felt normal last night. Could it be something else?
Old Sep 7, 2011 | 02:46 PM
combat mediC's Avatar
Sounds like transmission. Check the fluid.
Old Sep 7, 2011 | 03:18 PM
SimonCL-S6's Avatar
^ +1
Old Sep 7, 2011 | 03:33 PM
StreetKA's Avatar
I think its clutch. If you are able to shift gears when the engine is off and u cant when its on im 100% possitive thats clutch. Who did the clutch ? Do you have paperwork on it any warranty ? Checking tranny fluid will help too.
Did you replaced complete clutch with disc pressure plate bearings ? What about flywheel ?
I think something happened with the fork that it doesnt disengage clutch. Thats why u cant shift when the car is running. It might be something stupid like checking clutch fluid maybe it leaked or slave cylinder got damaged. Check those things first before u drop the tranny. If u have warranty on the clutch just go there and tell them whats wrong.
If u have more questions do ask it here or just pm me
Old Sep 7, 2011 | 03:41 PM
azeezp13's Avatar
shifting at 7k
Well I got it towed to a shop so I can't even check the fluid right now. Would old or lack of tranny fluid really cause all that?
I just bought the car last week. The previous owner replaced the clutch + timing belt/water pump about a year ago, showed me the receipts for it. But it was all done by random mechanic shops, I doubt there's any legitimate warranties or anything on that.
I'm expecting it to be clutch, got quoted for $1000 parts + labour. I'm thinking it could possibly be a throw out bearing as well. I won't find out till tomorrow though when they check it out. Thanks guys.
Old Sep 7, 2011 | 03:52 PM
I doubt its the clutch... I installed a cheap 200dollar autozone clutch in my turbo eclipse, ran it at 20lbs of boost and that clutch lasted 2 years until I sold the car, Im sure its still holding up.
StreetKA's Avatar
Too bad u got it towed already u could possibly fix it yourself if it was something easy like clutch fluid or slave cylinder but try argue with them. I dont think that you will have to replace disc and pressure plate since they are 5k (but that depends how threatened the car after install and break in period. )
Did u towed it to the same shop that did the clutch previously ?
Old Sep 7, 2011 | 04:06 PM
azeezp13's Avatar
shifting at 7k
Well if it's a tranny problem then I'm f*cked. I'd rather a blown clutch than a blown tranny. I'm going tomorrow to check out the fluids, and no it's not the same shop.
Old Sep 7, 2011 | 04:09 PM
StreetKA's Avatar
if the thing was done at the stealership you would have 12mo/36k warranty
Old Sep 12, 2011 | 04:47 PM
civicdrivr's Avatar
I doubt its the tranny itself. If the pedal feels weird then its most likely the master or slave cylinder. Otherwise, Im confident the clutch is shot.
Old Sep 12, 2011 | 08:16 PM
StreetKA's Avatar
update ?
Old Sep 21, 2011 | 09:00 AM
Sonnick's Avatar
All motor
Same thing happened to me with the CM FX200. Idk what it was. I'm so pissed because the tech already put the stock clutch back in.
Try adjusting the pedal. Someone told me that should work. As simple as that is, that could potentially be the reason why I now don't have the Stage 2/LW flywheel in my car.
Old Sep 22, 2011 | 12:41 PM
civicdrivr's Avatar
Sonnick - The clutch fork needs to be shimmed a bit to get full pedal throw. Thats the issue Paul had with mine when he installed the stage 3 CM kit.
Old Dec 17, 2011 | 10:39 PM
berettashooter25's Avatar
Honda/Acura Technician
Low transmission fluid most likely wouldn't cause this, seeing as the car has the 6-speed manual. As someone listed above, it seems more like a throw-out bearing issue (the bearing that the pressure plate of the clutch rides against when the clutch pedal is pushed down). If the throw-out bearing is somehow damaged, even in minor ways, this could cause the pressure plate to not fully depress, leaving it in an "engaged" state. This would also cause the car to not shift while on and then shift while off. Do not let your local mechanic replace the whole clutch until they thoroughly inspect the throw-out bearing and the arm that actuates the throw-out bearing. That's really all I can say about the situation without seeing the car myself.
Old Dec 18, 2011 | 10:10 AM
StreetKA's Avatar
I would say clutch isnt that expensive. I would replace everything to have piece of mind. Labor costs more than a clutch itself so if that just a bearing why not to replace everything to save labor next time?
Old Dec 18, 2011 | 12:15 PM
civicdrivr's Avatar
Same reason you should replace the rear main seal while the tranny is out.
mugen_kid
Nov 13, 2015 10:38 PM
Sep 14, 2015 03:16 PM
theinsvnity
Sep 10, 2015 10:22 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
heyitsvic
Sep 4, 2015 09:38 AM
