Replacement HID bulbs
Front headlights are not coming on. is it possible to simply replacing the headlight bulbs like regular headlights? I know it takes a special bulb, just wanna replace it my self if possile.
After you check the fuses if they are ok then replace the bulbs and it still doesn't work then you need new ballasts. Another member is currently selling 2 Oem Ballasts and Oem bulbs for $200 plus shipping that is a deal and if you end up needing them jump on it right now because those usually cost $200+ each.
Check the fuses first if both of them aren't coming on
