Replacement HID bulbs
Old Mar 16, 2010 | 12:31 AM
Jcayo11's Avatar
4th Gear
Front headlights are not coming on. is it possible to simply replacing the headlight bulbs like regular headlights? I know it takes a special bulb, just wanna replace it my self if possile.
Old Mar 16, 2010 | 11:01 PM
Seymore Cake's Avatar
'01 Acura CL Type-S
You need D2R HID bulbs Philips is your best bet.
And if both bulbs went it might be more than just your bulbs
Old Mar 24, 2010 | 05:32 AM
sloojoe's Avatar
fuses
first i would check your fuses. the headlight fuse box is located under the hood.
joe
Old Mar 24, 2010 | 08:47 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Check the fuses first if both of them aren't coming on
Old Mar 25, 2010 | 07:02 PM
clpassenubye's Avatar
ABP-KBP-CBP & ME
After you check the fuses if they are ok then replace the bulbs and it still doesn't work then you need new ballasts. Another member is currently selling 2 Oem Ballasts and Oem bulbs for $200 plus shipping that is a deal and if you end up needing them jump on it right now because those usually cost $200+ each.
oo7spy
Jun 19, 2023 12:48 AM
pozebly
Sep 23, 2015 07:30 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
voigt
Sep 2, 2015 10:44 PM
