Problems with the AC Compressor
Old Feb 12, 2009 | 08:30 PM
gangstaTL03's Avatar
gangstaCL03
When the A/C is on, the compressor makes a great amount of noise as if the bearing or some spinning component has gone bad. It sounds like a whine as if I have a SuperCharger on it when I give it some gas with the AC on. When its off, there is no noise.
How can I effectively fix this problem? The original owner has replaced the AC Compressor with a remanufactured compressor along with the accumulator at the end of 07. I wonder why it has gone bad again?
Old Feb 12, 2009 | 08:34 PM
gangstaCL03
If I were to go back to the dealership to have it fixed, would my CL with 84,000 miles be covered under warranty?
Old Feb 12, 2009 | 10:31 PM
Zippee's Avatar
Honda often puts a 1 year warranty on parts if they did the work. Did the dealer do the compressor change? You might call them and ask.
Old Feb 13, 2009 | 08:11 AM
fuzzy02CLS's Avatar
It's ether a bad belt or a bad belt tensioner. Likely is not the compressor.
Old Feb 15, 2009 | 10:44 AM
gangstaCL03
Thanks guys, I've talked to a couple technician friends over at the ACURA dealer.
He said that there is a possibility that one of the AC lines have a kink or something in it, causing high pressure to the Compressor. Therefore, resulting with metal shavings possibly floating around in the AC system. This of course is the worst case scenario.
However, he also did say it could be the compressor clutch going bad.
If it was a bearing, he said the compressor would be making a slight noise even when the compressor is off and progressively gets worse as I put more of a load on it.
As belts being a possibility.. I am not sure..
Old Feb 19, 2009 | 01:08 AM
aznboi2424's Avatar
i was gonna say it might be the clutch since it only happens when the AC is engaged.
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
