Power lock fuse
6th Gear
Power lock fuse
i have a parisitic drain and i have just about located it! What is the location of the fuse for the power locks and the alarm in the fuse box?
Also does anybody know a way I could pperform a parisitic drain test? I am a college student and trying my best not to spend any more money than i have to
The easy way to check for a drain is,get a test light disconnect the NEG battery terminal and connect test light between the neg on the battery and neg terminal you have just disconnected.Make sure everything is turned off,don't leave the door openand if you have an under the hood light disconnect it.If there is a draw in the system the test light will light up,depending on the amount of voltage or amperage in the draw depends on how bright the test light will glow.
To find out what it is that is causing the draw,start pulling fuses until the light goes out.
xsilverhawkx
09-28-2015 06:51 PM
ripit
09-26-2015 06:19 PM
