P1710 Help
Old Jun 1, 2014 | 09:34 PM
xJustin8x's Avatar
P1710 Help
CEL is on with code P1710. I could not find much info regarding this code when doing a search. The info I have found is:
- Faulty Gear Selection Switch
- Gear Selection Switch harness is open or shorted
- Gear Selection Switch circuit poor electrical connection
Where or what should I start with in trying to solving/fixing this code? Also, I do have this problem that I started a thread about that may be related to this p1710 code:
https://acurazine.com/forums/2g-cl-2001-2003-50/very-weird-symptom-911854/
Old Jun 2, 2014 | 06:27 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
If u are throwing that code it sounds like u may have lucked out and need to just replace the 1st hold switch
That is all the bible has to offer you good sir.... Good luck to you. Enjoy
Old Jun 2, 2014 | 02:57 PM
xJustin8x's Avatar
I hope so! Anywhere you can point me to that I can find out more info on replacing the 1st hold switch?
Old Sep 1, 2016 | 04:55 PM
Jersey201's Avatar
5th Gear
P1710
. Did you ever fix it what did you change I'm having same problem 2003 MDX p1710 how I can fix it ? I don't understand it's a harness wire or sensor that need to be replace ??
Old Sep 8, 2016 | 08:57 AM
johnboy1313's Avatar
Did you follow the steps provided in the pictures above?
Old Sep 8, 2016 | 01:49 PM
Jersey201's Avatar
5th Gear
. No yep my question is what's the problem it's a plug or what is the 1st hold switch ?? Can I test the wire with amp tester or just a regular electric test ? I dunno nutting about cars I just drive n put gas ...
Old Sep 8, 2016 | 01:53 PM
sounds like you might wanna take it to somebody else.
Old Sep 8, 2016 | 01:58 PM
Jersey201's Avatar
5th Gear
. Do u have the same problem before ? Code p1710
Old Dec 10, 2019 | 11:15 PM
Caleb Firebaugh's Avatar
i had an acura come in for me to work on (i run a very small shop out of my house but im not your typical shade tree mechanic) but this one threw me for a loop it runs terribly i was told it wont pull a hill it has exessive oil in the intake manifold it has a miss from hell but the only code it threw was p1710 now my scanner says thats for clutch something or other but it didnt list that code for honda if the torque converter lockup clutch is engaging that would cause the rough idle most definatley but as stated above its a pretty straigt forward code (not a symptom code with problem up or down stream) im not expecting people on here to fix my issue just help me understand why this car with clear issues would throw such a benign code oh yeah and i cleared the computer and it didnt run like a top but the missfire had definite improvment it also has an exaust leak near the cat pretty sure a clogged cat and yes i know a clogged cat can cause these issues but why no other diagnostic codes im about to do more research and a compresion check and diagnose the problem the old fasion way but is there maybe a data link issue causing the ecu not to communicate with the pcm and possibly obd port
Old Dec 10, 2019 | 11:25 PM
oh i should have mentioned the wiring to the ignition coils caught fire at one time she said the cars never run right and no one has properly fixed the issue im thinking this may be a pcm issue of some sort
Old Dec 11, 2019 | 12:28 PM
whitetiger5's Avatar
HI Caleb, a few questions:
what year car is this?
assuming it is a 2G TL:
The code you gave is associated with the transmission's clutch mechanism, there is a way to troubleshoot it, and another person with similar problems here:
https://acurazine.com/forums/second-...-steps-977726/
Also, when you say it can't make it up the hill, what do you mean? some kind of problems with slipping?
Have you checked the EGR system to see if it requires cleaning? That's also a common problem with random misfires, unless the misfiring cylinder is consistent, then I would check the circuit for that since you stated that there was a fire at one point.
ArTL-S
Jun 4, 2011 01:04 AM
turkeybaster115
Feb 15, 2010 01:17 AM
beestea
2G CL Transmission Recall Q & A
Jun 15, 2007 02:28 PM
