Overheating, radiator fan running 10+ mins
Old Aug 13, 2015 | 03:49 PM
DLntheCL's Avatar
Yes ive used the search function and google, and have read topics about the fan temp sensor A and main cooling fan senor, radiator temp sensor etc then i read well this is for premium model not type S and one guys says do this then another says do that, so Im really confused on what I need to replace or do......
85% of the time driving temp is fine, but at times it creep up to 3/4 hot, usually ill blast the heat and be unbearable for a min and it goes right back down. after parking my fan will go on for an extended amount of time. the fan issue has been going on for about a month or two, where as my overheating issues just started a week ago. thank you for your help!
Old Aug 14, 2015 | 11:23 AM
mattcl-s's Avatar
have you tried replacing the thermostat?
Old Aug 14, 2015 | 12:09 PM
DLntheCL's Avatar
no i havent....guess i can start there. thank you
Old Aug 20, 2015 | 12:38 PM
aznboi2424's Avatar
I'm assuming coolant levels are good? Change out the radiator cap too while you're at it.
Old Oct 29, 2015 | 01:13 PM
ptech904's Avatar
7th Gear
Did you ever get this resolved?
Old Oct 29, 2015 | 01:14 PM
^each case is different. this means if your car is over heating, it may be different than his case.
please fill us in on the details on what your car is doing, and maybe we can help trouble shoot it with you
Old Oct 29, 2015 | 02:06 PM
ptech904's Avatar
7th Gear
I'm new to AZ and my 03 CLS auto once had the fan run for a long time. So when i came across this thread I read it for info purpose. My car hasn't done this since the one time but I would like to know the fix in case it does.
I appreciate your response though!
Old Nov 1, 2015 | 05:01 PM
Lavor242's Avatar
Im having the same exact problem. could be allot of things but im gonna start by buying a thermostat.
TL-Rocket
Dec 4, 2017 06:59 AM
01CLOwner
Oct 9, 2015 01:07 PM
Sep 17, 2015 09:01 PM
Aleax
Sep 14, 2015 07:39 PM
NSolace
Sep 3, 2015 08:02 PM
