Our Fog lights
Old Dec 29, 2011 | 02:22 PM
Silver Bullet CL-S's Avatar
Our Fog lights
Does anyone know if we can HID our fog lights (accessory lights) ? cause the bulbs look like sidemarkers bulbs which are pretty small
Old Dec 29, 2011 | 03:33 PM
aznboi2424's Avatar
Not without modification to the housing. Since it's made of plastic, there have been members reporting that it starts to melt with the heat. You can upgrade to 12 watt bulb but I can't remember the bulb size off the top of my head. The stock sized bulbs are 5 watts.
Also please use the search function next time. This topic has been covered many times before.
Old Jan 5, 2012 | 06:36 PM
dante76's Avatar
i put in an accessory PIAA light...they look much better that those stock amber lights but doesn't do squat for seeing the road.
Old Jan 5, 2012 | 07:18 PM
p.diddy's Avatar
lol there called road lamps. there not made for you to see but for others to see you. if you want to go hid fogs you have to go custom like i did.
http://www.flickr.com/photos/58529986@N05/6360179921/http://www.flickr.com/photos/58529986@N05/6360179921/ by http://www.flickr.com/people/58529986@N05/, on Flickr
http://www.flickr.com/photos/58529986@N05/6360186599/http://www.flickr.com/photos/58529986@N05/6360186599/ by http://www.flickr.com/people/58529986@N05/, on Flickr
Old Jan 9, 2012 | 02:47 AM
Seymore Cake's Avatar
'01 Acura CL Type-S
LED's for the win
Before LED's:
After LED's:
Old Jan 9, 2012 | 11:05 AM
dante76's Avatar
are the led's a simple bulb type or is that a fog light conversion?
Old Jan 13, 2012 | 08:26 PM
'01 Acura CL Type-S
Leds are just a simple bulb, just like our regular bulbs
Old Jan 29, 2012 | 02:35 PM
jdavidm's Avatar
Here's a website you may find helpful:
http://www.superbrightleds.com/cgi-b...FQTNKgodwiZRvg
Old Jan 30, 2012 | 02:33 PM
what size do we use for the LEDS?
Also @ Pdiddy how did u customize your fogs? seems complicated from the other threads
Old Feb 1, 2012 | 04:03 AM
'01 Acura CL Type-S
I used these bulbs in the pictures
http://www.ledwholesalers.com/store/...&productId=458
The White, not warm
Old Mar 25, 2012 | 01:13 PM
drn33's Avatar
The White, not warm
OK. I'm going with these. Thanks for the link.
I did notice there are two holes (upper & lower) where the bulb can go in the light housing. Current bulbs are in the lower. Any comment on this???
Old Mar 26, 2012 | 12:37 AM
'01 Acura CL Type-S
I don't know about that because I recently took out the fog light housings to alter them for a larger bulb and there's only one hole
Old Mar 27, 2012 | 12:51 PM
aznboi2424's Avatar
Yea, there should be only 1 hole.
Old Apr 8, 2012 | 12:44 PM
drn33's Avatar
Yep one hole. I was seeing a reflection when looking into the light which created an optical dillussion. The LED's fit and work great. NICE!
Old Apr 9, 2012 | 02:49 AM
'01 Acura CL Type-S
Good to hear
Old Apr 10, 2012 | 01:04 AM
dre757's Avatar
9th Gear
Do the LEDs get too hot?
Old Apr 10, 2012 | 02:23 PM
aznboi2424's Avatar
LEDs should emit little to no heat especially compared to incandescent bulbs.
Old Apr 10, 2012 | 02:47 PM
dre757's Avatar
9th Gear
Alright. thx.
Old Apr 12, 2012 | 07:46 AM
Bazla's Avatar
2013 Infiniti G37S
Do any of you guys have a photo of the LED lights showing the road ahead w/o the headlights? Its been real foggy here and I need something functional not just cosmetic. Thanks.
Old Apr 12, 2012 | 02:22 PM
aznboi2424's Avatar
I find LEDs are more cosmetic then functional. They don't throw a lot of light out but if you look at them head on, they look real bright.
Old Apr 12, 2012 | 08:12 PM
civicdrivr's Avatar
If you want function, stick to proper halogen fogs (HID, since the are so close to the ground, will glare, especially on wet roads).
Old Apr 13, 2012 | 02:20 PM
Bazla's Avatar
2013 Infiniti G37S
Thanks guys.
Old Apr 14, 2012 | 10:43 PM
moddog27's Avatar
wow, thank you all for the info, i just joined and love how everyone here is so helpfull again thank you all for this info ive been looking for it.
Old Apr 26, 2012 | 06:17 PM
Cruz_msl's Avatar
My Member is Registered
Thanks alot you butt-heads, I came to the forum for an ignition issue and I end up buying fog lights
Old Apr 26, 2012 | 06:25 PM
civicdrivr's Avatar
Our job here is done
Old Jul 3, 2012 | 01:16 AM
'01 Acura CL Type-S
Meant to post up the car with the bigger LED's installed
Old Jul 3, 2012 | 02:19 PM
mikebikelife's Avatar
@Mikeshlong On IG
Seymore what bulbs are those bigger ones ?
EDIT: Link if possible please , I've always wanted to change out my halogens to those
Old Jul 3, 2012 | 10:09 PM
'01 Acura CL Type-S
Well the bigger led's require you to modify the light housing by basically cut out what the bulb locks into
I'll post the link when I get to an actual computer
Old Jul 4, 2012 | 02:39 AM
'01 Acura CL Type-S
http://www.ledwholesalers.com/store/...&productId=688
It should be the 18 LED wedge bulb, make sure you get the "white" and NOT the "warm white" if you want it to look like mine
Old Jul 4, 2012 | 04:54 AM
@Mikeshlong On IG
Thank you Seymore, I'll order some up.
Now to find diy on how to make them fit.
Can you still put halogens back in after modifying ?
Old Jul 4, 2012 | 05:07 AM
@Mikeshlong On IG
Just looked for over ten minutes for a thread on doing this and cannot find one :l Help guys ?
Old Jul 5, 2012 | 05:07 AM
'01 Acura CL Type-S
Once you make the mod you can't go back to the regular stock bulbs
You would have to have a second set of housings to revert back
When you take the housings out and the hole in which the bulb locks into you have to cut out the teeth in the hole that lock in the bulbs. I used a heated knife and melted through them
Old Jul 25, 2012 | 01:24 AM
malvothegreat's Avatar
What hid bulb should you use in the road lamp housing?
Old Aug 18, 2012 | 02:44 PM
Mopply's Avatar
So Seymore, the LED's you linked for in the first picture will fit with no modification?
Old Aug 19, 2012 | 03:48 AM
'01 Acura CL Type-S
Yes the first bulbs I linked fit right in without having to alter anything
Old Aug 25, 2012 | 09:29 PM
hotclick56's Avatar
2023 TLX
HID bulb in the road lamp housing
This is how I approached the driving light situation: I added the 2003/2005 2 door Accord driving light kit to my CL.
But instead of using the halogen bulbs, I used the H11 Osram 5500K HID bulb and the wiring harness from the www.retrofitsource.com
http://www.theretrofitsource.com/pdf...on_Harness.pdf
And here is how my CL looked like:
Old Oct 2, 2012 | 07:05 PM
karanmc's Avatar
hey seymore, check this link out....i want to get the fogs changed to led will they fit http://www.ebay.com/itm/Car-T20-5050...3266b9&vxp=mtr
Old Oct 3, 2012 | 10:34 PM
99 Chris's Avatar
I like peanut butter
THIS is what I've searched for in the past!! I'm probably going to copy you, hope you don't mind. Thank you!
Old Oct 3, 2012 | 10:46 PM
99 Chris's Avatar
Also Hotclick56, did the Honda kit fit into the Acura's driving lamp light slot? Or any modifications needed to fit?
Old Oct 4, 2012 | 12:45 AM
'01 Acura CL Type-S
You might have to modify the housing of the road lamps for these bulbs to fit. I really can't tell the dimensions of the bulb from the picture to be sure if it will fit right in or not.
