Oil Leak
Old Aug 25, 2012 | 09:01 AM
ACCOUPE's Avatar
Oil Leak
I have an oil leak around around the oil pump area of my motor (stock). Im believe its coming from the oil pump housing. Should I replace the Oil pump housing and the seal inside or should i just replace the inside seal. Has anyone had experience with this or do the know for a fact what it is because the motor maybe known for it?
Old Aug 27, 2012 | 11:44 AM
Catfisha's Avatar
Giant Blue Car
I don't know if there would be a cost-benefit to going ahead and buying a new oil pump; at the same time, you can go ahead an do your timing belt since you're there...but definitely use new seals!
And, be sure to thoroughly clean off the old liquid gasket crap off the surfaces! Use Hondabond or Ultra Flange as the new "gasket" and on the inner threads of the bolt holes.... Time the application carefully since the liquid sets pretty fast!!
Old Aug 30, 2012 | 08:11 PM
StreetKA's Avatar
pretty much what he said... use hondabond
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
