O2 Sensor Wire
Old Mar 20, 2015 | 09:48 PM
bcart180's Avatar
O2 Sensor Wire
I've done plenty of searching.
I looked under my car and noticed my aft O2 sensor wire cut and hanging. Where is that cable routed to? Is there a wiring diagram so I can re-wire?
Old Mar 20, 2015 | 10:19 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
There should be a clip under the car about a foot/Foot and a half from the O2 sensor location. If the clip is gone and the wire is cut before the clip you will need to replace the clip by soldering on a new wire with the clip. That's what I would do at least. Instead of buying the O2 sensor then cutting it. But it's up to you.
Do not just use connectors cause the impedance will be different and may cause issues.
RobbDizzle
Oct 15, 2015 11:16 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
