NO Heat in the CL
Old Oct 3, 2009 | 03:17 PM
Bursaliozer's Avatar
NO Heat in the CL
Hey guys,
01 CL-S Auto with 144k
I turned up the heat the other night because it gets cold here in upstate NY and noticed i dont have heat. I turn it upto 90 and air comes out the vents but its cool outside air. If i turn the AC on then it gets much colder as it should.
The motor was replaced in this car so i checked to see if the coolant line was hooked up and i see a line going into the firewall. Any ideas?
Old Oct 3, 2009 | 05:25 PM
neyeswhip's Avatar
tigerstyle
thermostat
Old Oct 3, 2009 | 10:52 PM
friesm2000's Avatar
B A N N E D
might be a stuck or disconnected heater control valve (be in engine compartment along the firewallwith one of the heater hoses going through it) (would not allow coolant to flow to the heater core)
Old Oct 4, 2009 | 08:33 PM
Is there only one hose going into the heater core? I didnt see anything thats disconnected. Car doesnt heat up or anything, operates just like normal. Just no hot air for the cabin, hmm
Old Oct 4, 2009 | 11:22 PM
friesm2000's Avatar
B A N N E D
there are two hose's one to supply and another one to return and valve will be in the supply side one
Old Oct 10, 2009 | 05:14 PM
ok i saw the valve and kinda opened it and closed it. Im getting some heat now, maybe it was stock at closed position. Thanks!!
Old Sep 17, 2010 | 11:40 AM
Aladdin's Avatar
im having the same problem, where is this valve located, any pic on it ?
Old Sep 22, 2010 | 10:05 AM
MPJ100's Avatar
Aladdin,
Did you ever find out the fix for the no heat issue? I'm having the same problem. Anything you can provide would be a great help.
Thanks!!
Old Sep 22, 2010 | 10:07 AM
MPJ100's Avatar
Aladdin,
Thanks,
M
Old Oct 11, 2010 | 02:42 PM
its on the firewall, passenger side. You will see a cable that comes out the firewall into the coolant hose. This cable moving back and forth is what regulates the amount of coolant. Just jiggle it and it should work after that. Hope that explains it.
Jul 16, 2017 07:33 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
TL14
Sep 24, 2015 04:37 PM
