My first problem... rev bounce
Old Oct 27, 2015 | 11:36 PM
mike88se's Avatar
I've only driven the car once for a short distance since I installed the CAI and headers. Tonight I was going to drive it to the store. The first time I drove it the idle was perfect. When I cranked it up tonight the tach went to 1200. And then it started bouncing between 1200 and ~2000 alternating w/ a 1000 to 2000 bounce. Steady bounce... never resting at either point.
I figure it has something to do with the recent new parts.
Maybe the Bosch O2 sensors I was warned about? But I think I read a post here about a similar problem that was caused by some type of valve inside the intake manifold or the part that controls that valve. I haven't found that thread again and don't recall the part name. An acronym was used. IACV or something like that but not the idle air control valve. The actuator or controller is located on the back side of the IM and has a cable like a throttle cable. I unplugged the electrical plug and loosened the bracket to get more room to get to the exhaust manifold nuts. I was careful handling it and when I reattached the bracket and plugged the electrical connector back in it looked just the way it did before I toughed it. So I'm leaning towards the Bosch sensors.
Any thoughts on this?
Old Oct 28, 2015 | 01:25 AM
01acls's Avatar
Well if the car was fine before the mods then it must be something you did during the mods. Most likely the CAI... vacuum leak or vacuum hose left unpluged.
^ Are you talking about the idle srcew?
Old Oct 28, 2015 | 03:39 AM
mike88se's Avatar
Ummm yeah, as I said there is a good chance it has something to do with the recent work altho it seems odd that it didn't appear the first time I drove it. No vac leaks and no hoses unplugged.
I've never looked for it but I'm pretty sure the idle speed screw is on the TB. It definitely wouldn't get in the way of exhaust manifold nuts. This isn't an idle surge, the tach needle is bouncing back and forth continuously between 1200 and 2200. No creeping or surging... straight up to 2200 and then straight down to 1200 like a metronome.
This is the part I'm talking about. It's called a bypass valve actuator but I haven't found out what it does.
Old Oct 28, 2015 | 03:54 AM
01acls's Avatar
See link below.
https://acurazine.com/forums/second-...-valve-486904/
Old Oct 28, 2015 | 04:09 AM
mike88se's Avatar
Yes I was just reading about the Intake Manifold Runner Control. I suppose I'll cross that off the list of possibilities. I was leaning towards those new o2 sensors but I've never seen a bad o2 sensor cause something like this. Matter of fact I've never even seen a car do something like this. Its like bouncing off a 2200 rpm rev limiter.
Old Oct 28, 2015 | 06:16 AM
mike88se's Avatar
I went out this morning and started it up and the idle was normal. Must be gremlins...
usdmJON
California
Sep 20, 2016 03:32 PM
cudfoo
Jan 8, 2016 07:46 PM
dezymond
Nov 6, 2015 12:45 AM
David_BNSF
Oct 26, 2015 12:50 PM
Doom878
Oct 23, 2015 03:30 PM
