Is my engine really done??
Old Jun 13, 2009 | 04:11 AM
Nersh7's Avatar
I Drive Like A Dick 8≈
Exclamation Is my engine really done??
After noticing some squeaking coming from my engine and a bit of smoke out of my exhaust I decided that it was a good idea to take my CL to the dealership to get it checked out. What I was told (btw salvaged title) was that some idiot had driven a bolt that did not fit into the block that holds the alternator in place, causing it to sit crooked and squeak, the bolt was the wrong size and seized. If he tried to take the bolt out and stripped the threads the block was done(can't it just be rethreaded???). ANNND ontop of that my piston rings were starting to go.(didnt do a compression test)
So my question is... is this mechanic right or wrong, and can i fix it without spending a rediculous amount if hes wrong?
Old Jun 13, 2009 | 04:16 AM
blackasscls's Avatar
Did you ask him how exactly your engine would be done if he stripped the threads out? I think you can definately just re-tap it...unless there are coolant passages or something right next to the bolt hole. If you have smoke coming out the piston ring thing is probably not a lie, if you know how to do work on cars do a compression test yourself and see if it is or isn't in spec. Personally I believe piston rings could be replaced very easily and shouldn't take you more than a day or two.
Old Jun 13, 2009 | 08:16 AM
corsair's Avatar
Pilot Extraordinaire
Not a problem to any half assed mechanic. Easy re-tap job. The dealership wants your $$$$$.
Old Jun 13, 2009 | 08:30 AM
fsttyms1's Avatar
The question is is why would that cause smoke to come out of the exhaust?
Old Jun 13, 2009 | 09:13 AM
corsair's Avatar
If your piston rings are worn (a compression test would indicate this) that would be the smoke issue. Who told you your rings were worn? It could be valve guides or valve seals. These are all oil burning issues. If it is white smoke it could be a coolant leak, like a head gasket. Find a good mechanic, not a dealership. Talk to people you know to recommend a mechanic. I can't help you up there in the Great White North. Sorry.
Old Jun 13, 2009 | 09:43 AM
civicdrivr's Avatar
x2
Old Jun 29, 2009 | 01:47 PM
Nersh7's Avatar
Ya the mechanic seemed like he was just out for $$$$ but the smoke was blue so unless something else burns blue it must be oil. Trying to find a good mechanic whos not just looking to make a big bill is tough.
Old Jun 29, 2009 | 02:22 PM
Pseudomaniac's Avatar
Blue? You throwing any EGR codes?
SidhuSaaB
May 30, 2020 12:40 AM
BIGxRED
Oct 19, 2015 10:47 PM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
