My car is pulling to the sides under acceleration
Old Nov 7, 2009 | 09:53 AM
StreetKA's Avatar
i noticed about week ago that when i do accelerate hard car pulls to the side on first and second gear... could be alignment ? or lower ball joint ? or what? and also when i turn my steering wheel and take of i hear clicking from axle i think could bo gone bad right ? the driver side thanks for help !
Old Nov 7, 2009 | 12:56 PM
civicdrivr's Avatar
If the axle is clicking, replace it. If the joints completely seperate you can damage your LSD.
If the pulling is still there after the axle replacement, then check tie rod ends and ball joints.
Old Nov 14, 2009 | 08:56 AM
phee's Avatar
I got the Shifts
my car pulls to the right under hard acceleration. its always done it and it drives me nuts. even with a perfect alignment
Old Nov 14, 2009 | 09:18 AM
celynka's Avatar
Sundance Gold in
Just get you CV joint done first
Old Nov 14, 2009 | 11:24 AM
friesm2000's Avatar
B A N N E D
yeah get the axle fixed, but yeah some of that pull is called torque steer especially if you are accelerating hard (aka WOT)
Old Nov 18, 2009 | 02:24 PM
CLSspeedx's Avatar
I hit the curb at the bank drive through (don't even get me going!) and just replaced the right front rod, and a new lower control arm is going in sunday. The rod replaced most of the problem, but with the bent lower arm in place the car sits just a bit low on the passenger side, visible when the car is on level ground.
Old Nov 18, 2009 | 02:31 PM
crazyasiantl's Avatar
+1 on torque steer
Old Feb 4, 2010 | 08:09 PM
boostedcls6's Avatar
I have the exact problem. I have replaced both upper control arms, numerous alignments, chaged rims/tires, replaced both axles, changed lower control arms, radius arms and bushing. both outer tie rods, and have brand new tein coilovers. i just ordered a new sub frame to see if it fixes it, but it is driving me nuts. i dont know what it is, but it pulls to the right when accelerating. i have a 6 speed with lsd, so dont make sense?
Old Feb 4, 2010 | 08:19 PM
friesm2000's Avatar
B A N N E D
you can't expect it have absolutely no torque steer, and to the right is extremely sensibly, it's the extra length caused by the extension shaft for the passenger side axle
Old Feb 4, 2010 | 08:26 PM
but i could have sworn our car shave near equal shafts, and that the car never did this b4?
Old Feb 4, 2010 | 08:36 PM
friesm2000's Avatar
B A N N E D
equal length shafts, kinda, if you count just the section between the joints then yes
but when you include part #17, no way in hell are they equal length
and "before", are you talking about when you where at "stock" power levels, if so, the engineers had already compensated for the torque steer by varying how thick the axles are and such, but now with more power, that built in compensation is insufficient for your higher power levels
Old Feb 4, 2010 | 08:41 PM
so is this something i have to live with, or something that can be corrected with a caster kit?
also, i am currently pretty much stock. minus the stage 4 clutch and light weight flywheel, yet it still pulls, even after replacing everything? the only other sympton i notice is a vibration while accelerating in first and second gear. I will take a video tomorrow and post it up to show exactly what occurs, and perhaps a better diagnosis can be made. also i will post my last spec sheet for alignment.
Old Feb 4, 2010 | 08:46 PM
friesm2000's Avatar
B A N N E D
to add caster on our cars, all you do is remove some shims:, but no that will probably not help at all (maybe a little, but not the source of the toque steer)(and i thought you were boosted :shakehead)
check you motor mounts first, motor may be shifting around too much, causing different angles and such with the axles, so the torque steer
Old Feb 4, 2010 | 09:16 PM
i am boosted, but have removed the blower to install new 09 tl IM and ported runners, fuel rails etc.
I have poly filled my mounts with 60a but have noticed that some have started to crack. so poor mounts can cause my issues of pulling towards on side? have no choice but wait to see what happens after i change the sub frame and someone releases mounts for this car
Old Feb 4, 2010 | 09:25 PM
friesm2000's Avatar
B A N N E D
but the blower does not get in the way though of the manifold
and you said cracking, obviously overstressed, so motor is definitely moving around some
also try this (my thread )
https://acurazine.com/forums/2g-tl-1999-2003-98/ingalls-stiffy-etd-mount-760177/
should help with some of the motor mount issues, (not all, but some)
Old Feb 4, 2010 | 09:31 PM
https://acurazine.com/forums/showthread.php?t=760177
correct but also changing coils, plugs, etc but this is irrelevant to issue at hand. i will check ur thread now
Old Feb 4, 2010 | 09:32 PM
after looking at ur thread, id like to say that i ordered two
new nrg engine mounts, and see what that does as far as the vibration and pulling
Old Feb 4, 2010 | 09:33 PM
friesm2000's Avatar
B A N N E D
OK understandable for plugs, but why not right back on with the s/c then
Old Feb 4, 2010 | 09:35 PM
friesm2000's Avatar
B A N N E D
wrong mounts for where the ingall's would be going, it goes with the side mount on the passenger framerail, not the front and rear mounts
Old Feb 16, 2010 | 09:05 AM
StreetKA's Avatar
i still have this problem but noticed that my steeringwheel start to shake around 50-70 not much but thats anoying. first thing i did was balance wheels with no effect than alignment. now i think it may be axles so they are next on my list. also pass side engine mount went bad.
Old Feb 16, 2010 | 04:46 PM
friesm2000's Avatar
B A N N E D
you mean the side mount??? that bolts to the passenger side framerail
anyways i would also check the front mount, cause it was also bad/very weak when i did my side front , so had to also do it, then when i had it out, and started playing it (not even disassembly yet eitier, it tore just like everyone else's does, so it was not long for this life eithier
Old Feb 16, 2010 | 04:49 PM
StreetKA's Avatar
front is brand new and poly filled, side one is bad
Old Feb 16, 2010 | 05:21 PM
friesm2000's Avatar
B A N N E D
has it ever happened to of had a new axle put in it (maybe a non OEM one)
Old Feb 16, 2010 | 05:39 PM
StreetKA's Avatar
im sure thats bc of the way i drive and the axles are oem im sure
Old Feb 16, 2010 | 05:57 PM
friesm2000's Avatar
B A N N E D
also are you talking about a constent pull when you are in 1st and 2nd, or just that it kinda jerks when you first step on the gas
Old Feb 16, 2010 | 08:05 PM
StreetKA's Avatar
only when i floor it...
Old Feb 16, 2010 | 08:39 PM
friesm2000's Avatar
B A N N E D
like a constant pull as long as you are flooring it, or like a jerk when you first floor it, then it basically stays straight
Old Feb 16, 2010 | 08:44 PM
StreetKA's Avatar
thats hard to say bc when first time feel its start to pulling i try to hold the steering wheel stronger dunno...
Old Feb 16, 2010 | 08:58 PM
friesm2000's Avatar
B A N N E D
if it is like just a jerk, then it is kinda normal, but if it's a constant pull, it's not normal (you might get a little, but nothing drastic though, like something that 2 fingers on the wheel can correct)
Old Feb 22, 2010 | 05:36 PM
victorvu's Avatar
tie rods that would be your problem for shaking at a certain speed my car has that same problem and without good tie rods an alignment is useless. i replaced all my ball joints and both inner and outer tie rods.
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
2012wagon
Sep 29, 2015 04:21 PM
Phambam12
Sep 6, 2015 06:57 PM
