Misfired Cylinder Problem - P0302, P1399
Old Feb 21, 2014 | 01:55 PM
jrzofclay's Avatar
Hi all,
This morning my car started rumbling fairly moderately, and the CEL started flashing. Brought it in to my usual highly rated auto shop, and they got two codes:
P0302
P1399
After diagnostic, they said they found the spark plug and coil pack need replacing, and valve adjustment for the #2 cylinder. However, they recommended that I replace the spark plugs, coil packs, and valve adjustments for all 6 cylinders. Total quote was $1169! That seems a bit expensive.
I asked how much it would be to replace only the cylinder #2 spark plug and coil pack, and they said it would be $120, a very large difference from $1169.
Question:
1. Do I need to replace all 6? Do I need valve adjusting?
2. I asked about clogged EGR valve and they said they didn't check, but said that it's not really an issue. Doesn't seem to match up with what other people on this board think.
3. Do you recommend replacing the spark plug and coil pack myself?
Any other thoughts are appreciated.
Old Feb 21, 2014 | 02:04 PM
six speed or auto?
You should trouble shoot cylinder 2, by running the car and taking off that coil pack, if no change in sound, either the coil pack or plug is bad.
spark plugs are 7 bucks each.
$7x6plugs = $42.
6 coil packs are like = $50 bucks.
you can easily take off the EGR valve and clean it yourself.
your trusted mechanic isnt so trustworthy
Old Feb 21, 2014 | 02:09 PM
jrzofclay's Avatar
Thanks for the reply. The car is a 2001 3.2 Auto. ~165k miles. Agreed about the mechanic..
Old Feb 21, 2014 | 02:16 PM
the reason why I asked about the transmission, is because sometimes six speed manual owners will over-rev their car.
bending valves and hurting compression in cylinders
but in your automatic, you cant do that, unless it was over heated.
Old Feb 21, 2014 | 03:49 PM
jrzofclay's Avatar
Just spoke to the shop. They're hesitant to replace only one spark plug and coil pack. It also looks like the reason it's so expensive is because of the valve adjustment.
Old Feb 21, 2014 | 07:50 PM
gnuts's Avatar
3.5 psi
Plugs and coil packs are extremely easy to replace yourself. There are DIYs here and people to help if you have questions. You could even post in the region section to see if someone local would give you a hand for a case of beer.
If I were you I'd replace those and see how the car runs.
Old Feb 21, 2014 | 09:55 PM
jrzofclay's Avatar
Planning on replacing all 6 plugs, and the #2 cylinder coil tomorrow on my own. Will update as soon as it's finished. Any thoughts on the valve adjustment, though, assuming everything goes well with the plugs and coil?
Old Feb 21, 2014 | 10:09 PM
diy valve adjustments are tricky because A) you'll have to buy a feeler gauge. B) some can do it by feel.
it will get rid of the ticking sound at idle.
usually the exhaust valves get tight and the intake valves are loose.
align them to spec.
Old Feb 21, 2014 | 10:16 PM
gnuts's Avatar
3.5 psi
I adjusted my own valves and it was intimidating but not hard. Just take your time. And I've never even changed brakes before.
Old Feb 22, 2014 | 06:29 PM
jrzofclay's Avatar
Just finished replacing all 6 spark plugs (NGK Iridium IX), and the #2 cylinder ignition coil. Car is running perfect now! The only thing is..the other 5 cylinders are running on the old coils (only the #2 coil was broken). Could this have any long term effect?
Old Feb 22, 2014 | 08:43 PM
gnuts's Avatar
3.5 psi
Doubt it. A bad coil will quickly throw a code. Glad the car is back up and running.
Old Feb 24, 2014 | 12:12 PM
Tosh's Avatar
Eurotrash
On mine, coils 2 and 5 failed at the same time, so I swapped all 6 for new ones (Airtex/Wells brand from rockauto). Funny how it always seems to be #2 cylinder....
4drviper
Apr 23, 2025 07:13 PM
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
STL TL-S
Sep 23, 2015 08:52 PM
