Map Sensor????
Old May 7, 2007 | 08:45 PM
Houston_memorial's Avatar
9th Gear
Map Sensor????
I have a 1998 acura cl 3.0, I am experiencing a problem, when I press gas the odometer gauge goes up but car don't move.
I had same issue about 4 months ago and was told that "MAP SENSOR" was bad, replaced it (put used one in), that seemed to fix the problem, but I got the same issue again.
Any commensts / suggestions?
What exactally is "MAP SENSOR" and what is it used for, any help will be greatly appreciated.
Old May 7, 2007 | 09:08 PM
9th Gear
Map Sensor !!
Old May 7, 2007 | 09:16 PM
herbalist's Avatar
chips and smokes, lets go
search
http://www.acura-cl.com/forums/showt...ghlight=sensor
Old May 7, 2007 | 09:19 PM
CLpwner's Avatar
Mmmm...
Originally Posted by herbalist
whats taht 2 s in a row?
Old May 7, 2007 | 11:25 PM
Ron A's Avatar
Administrator
I deleted the two threads you posted in Frequently Asked Questions because you are not supposed to post threads in that forum, and I deleted the other two threads you posted in the 1G CL Forum since one thread is all that is allowed for the same topic. Be patient and you will get some replies.
The MAP sensor reads the manifold air pressure.
soupi
14
Nov 15, 2015 11:15 AM
RobbDizzle
Oct 15, 2015 11:16 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
