Map Sensor????
Map Sensor????
I have a 1998 acura cl 3.0, I am experiencing a problem, when I press gas the odometer gauge goes up but car don't move.
I had same issue about 4 months ago and was told that "MAP SENSOR" was bad, replaced it (put used one in), that seemed to fix the problem, but I got the same issue again.
Any commensts / suggestions?
What exactally is "MAP SENSOR" and what is it used for, any help will be greatly appreciated.
Map Sensor !!
Originally Posted by herbalist
whats taht 2 s in a row?
I deleted the two threads you posted in Frequently Asked Questions because you are not supposed to post threads in that forum, and I deleted the other two threads you posted in the 1G CL Forum since one thread is all that is allowed for the same topic. Be patient and you will get some replies.
The MAP sensor reads the manifold air pressure.
soupi
14
11-15-2015 11:15 AM
ExcelerateRep
10-14-2015 08:20 AM
