Ignition key problem
Old Oct 3, 2015 | 12:33 PM
Marsh_sochi's Avatar
9th Gear
Hi guys!
I got CL 1999 5MT. And l got problems with the ignition key - it turns, starts the engine, but with time key doesnt fixe in the exact position. And when you,ve started the engine - audio and 12V mostly doesn't work. So you have to turn key slightly forward and backward to find the exact position to start the audio. I've been doing it for 3-4 times every time i start the engine, so it have pissed me off!
Is there any other options, than changing whole 3 locks in the car?
TY!
Old Oct 3, 2015 | 12:36 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Do a search but I think you can swap out the ignition cylinder itself.
Old Oct 3, 2015 | 12:37 PM
9th Gear
Without changing keys itself?
Old Oct 3, 2015 | 02:23 PM
NBP04TL4ME's Avatar
Ignition switch failure is fairly common on your car, but not positive about the necessity to change the key itself. Do some searching to see if you can definitely determine that otherwise other members may be able to answer you. To get you started -
https://acurazine.com/forums/second-...thread-936949/
https://acurazine.com/forums/second-...switch-686000/
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
Ty-Sama
Sep 21, 2015 05:45 AM
merc009
Sep 14, 2015 06:43 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
