idiling problem
Old Aug 15, 2009 | 12:27 AM
South Africa's Avatar
8th Gear
Cool idiling problem
I recently put a j32a2 into my 92 civic and finally got her started the engine runs great for about 3 minutes and then the idiling picks up and drops and so on is there any body that can give me some advise on this .
Old Aug 15, 2009 | 01:29 AM
celynka's Avatar
Sundance Gold in
might be IAC valve
Old Aug 15, 2009 | 04:51 AM
aznboi2424's Avatar
vacuum leak?
Old Aug 15, 2009 | 04:12 PM
civicdrivr's Avatar
Bleed the cooling system. You probably have some air caught in the IACV causing the readings to be off.
You may need to adjust the IACV sensor too. Since this is a swap, youre not running the power steering or air conditioning, so its preconfigured to control idle with those loads on the engine. Dremel some slots into those screws, loosen it and twist the sensor a bit to adjust.
Are you throwing any codes?
Old Aug 16, 2009 | 09:55 AM
8th Gear
im sure im throwing codes but since this a 92 civic it did not come with a computer plug so i cannot check any codes plus im running the power steering .has any body done a swap like this yes there are some wiring questions that i have.
Old Aug 16, 2009 | 07:58 PM
civicdrivr's Avatar
Yea, theres quite a few people who have done this swap, but not on this forum. Id send you the links but you cant get pms yet.
Old Aug 17, 2009 | 08:04 AM
8th Gear
Cool re: links
please send me those links ive been busy with this project for a long time and i can use any help that i can get .thanks allot guys for helping me.
Old Aug 17, 2009 | 09:09 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
u say 3 minutes and then u get issues. That's when the car gets to temp and starts running in "closed loop" I think it is, which is when the car knows it's warm and then starts using all the sensors to determine a/f ratios and idle and so on.
So ur idle is probably at like 1000ish and then when she's warm it starts acting up? Insead of dropping, it becomes sparatic?
I had this issue and was the Idle air control valve.
Old Aug 17, 2009 | 02:13 PM
civicdrivr's Avatar
Since you cant accept PMs, Ill just post is here.
J32A (dot) com
Mods, if posting that is a problem please delete this post. Thankyou.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
