I just fixed this noise
Old May 11, 2010 | 09:49 PM
Nersh7's Avatar
I Drive Like A Dick 8≈
I recently like a month and a half ago replaced my lower ball joints after an annoying clunking noise from my suspension. Now I have the same noise but way worse from the same area, I was told that my tie rods probably needed to be replaced so now I have new ones on the way (inner and outer on both sides) but does this sound like its the problem or do I have a bigger problem??
Old May 11, 2010 | 10:00 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
My clunking was the upper ball joint hitting the strut tower.
It's easy to check you tie rods.
Turn your wheel so you can get a hand on the outer or as much as you can grab.
Pull in and out the normal motion it would travel.
If you feel it clicking,then,
Look closer if there play on the outer you will see it right away.
If it the inner the outer wont move at all and you will get the play (clicking) from the inner.
Old May 11, 2010 | 10:21 PM
Nersh7's Avatar
ok, would anything else cause this noise?
Old May 12, 2010 | 08:35 AM
NSXNEXT's Avatar
Could be a broken end link. It looks similar to this...connects to the front sway bar.
Old May 12, 2010 | 10:58 PM
Nersh7's Avatar
ok i will check that asap
Old May 13, 2010 | 06:42 PM
Nersh7's Avatar
CV axle was the problem
SidhuSaaB
May 30, 2020 12:40 AM
snorf
Nov 4, 2019 06:44 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Retep Nitciaj
1G RL (1996-2004)
Oct 6, 2015 01:36 PM
Papa Roe
Sep 26, 2015 11:45 AM
