humming / vibration, the shops can't figure it out.
Old May 8, 2007 | 05:53 PM
Flyway777's Avatar
8th Gear
My 01 cl-s makes a humming vibration noise while going straight, it becomes audible around 35mph and gets louder the faster I'm going. it goes away completely when i make a left turn, but gets louder when i turn right. dealership reccomended tires so i got new ones, didnt work. sears auto said wheel was bent, got new wheels, didnt work. then today my local shop said the drivers side wheel bearing is bad, replaced that. Still making the same noise. they suggested the passenger side bearing after they realized it's still making the same noise. ugh anyone have any ideas? im running out of money.
Old May 12, 2007 | 02:18 AM
celynka's Avatar
Sundance Gold in
did anybody check engine mounts
Old May 12, 2007 | 09:39 AM
fuzzy02CLS's Avatar
Or axle half shafts
Old May 17, 2007 | 09:56 PM
mu9en's Avatar
i'd say it's the power steering pump..
Old May 21, 2007 | 02:42 PM
PhilB81's Avatar
does the pitch change with your speed or based on throttle ?
Old May 21, 2007 | 08:16 PM
LIPPSTUH's Avatar
Unregistered user
damn man, get a good mechanic that will find the problem... sucks to spend so much money and not get it fixed.
Old May 24, 2007 | 10:30 PM
nigaphan's Avatar
9th Gear
Check the alternator, common humming noise on honda v6. Is it a whinning noise as you press the throttle goes higher? Check the alt. if it's a Delphi brand replace it.
Old May 25, 2007 | 07:38 AM
Flyway777's Avatar
8th Gear
ugh, still hummimg...
Old May 25, 2007 | 12:43 PM
Flyway777's Avatar
8th Gear
It's back in the shop today, if they fix it I'll let you guys know what it turned out to be, maybe itll make it easier for others down the road....
Old May 27, 2007 | 02:08 AM
Flyway777's Avatar
8th Gear
it was a wheel bearing. i guess from now on i know what that sounds like...
she sounds so clean and quiet now!
Old May 29, 2007 | 11:53 PM
cmchenry's Avatar
6th Gear
Bad wheel bearing
I think I have the same issue with my 06 CL-6 6 speed. It has pretty agressive Toyo tires and I have been blaming them for the obnoxious drone (everyone says it sound like I am flying a smal turboprop plane when on the cell phone).
Did they replace all four wheel bearings to be safe or were they able to isolate the one that was bad? What is the approx cost?
Thanks . . .
Old May 31, 2007 | 08:56 AM
cmchenry's Avatar
6th Gear
It was a bearing
Front drivers side bearing was bad. They diagnosed it with a stethoscope of all things.
Anyway, $283 later, shes smooth and quiet.
Old Jun 1, 2007 | 04:13 AM
nigaphan's Avatar
9th Gear
Good shops would put the issue on a ear chasiss (microphone suspension detection tool) and would pin-point the problem. Sad to hear that after all that repair it was a wheel bearing.
Old Jun 1, 2007 | 08:50 PM
oreo615's Avatar
At what mileage are these cars with bad wheel bearings?
Old Jun 2, 2007 | 11:40 AM
Flyway777's Avatar
8th Gear
I'm at 110k. cost was about $230/ side from the local shop. dealer wanted $450/side
Old Jun 2, 2007 | 05:54 PM
cmchenry's Avatar
6th Gear
My "03 (not 06) is at 80k now but the noise started at about 65k.
Dealer says they see very few bearing failures on the "newer" CL's but they are more common on the "95-98''s and such.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
MonkeyTrucker
Sep 21, 2015 06:15 PM
spoiler900
Sep 10, 2015 01:06 PM
NSolace
Sep 3, 2015 08:14 PM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
