Home-made Cabin Filter DIY
Old Jun 8, 2010 | 11:09 PM
Add-dee's Avatar
Noobalicious
This is not how to replace but how to make your money work harder...
I see a lot of you like to DIY-s so ...as I stick around you will find I am cheap, even with that said I dont like to sacrifice quality.
I made my own cabin filter(s)
and it was cheap if you have the screen just hanging out at your place.
the filter was about $7 at HomeDepot and you get a big @$$ sheet of it (see image). [yes I had this just lying around in the garage]
just take measurements of the stock filter and cut 4 sections of the new sheet to match. place 1 on top of another. use window screen or a material like it to lock (with thread or other) it all together. place new DIY filer in and your done.
when its time to maintenance, just remove, wash, let dry and replace.
if img code does not work here is the link:
http://s841.photobucket.com/albums/zz337/Add-dee/DIY/
LOL and dont give me $hit about the blue string (left filter was first attempt, right filter I took more pride in my work) ...hell no one will see it except you guys.
Old Jun 9, 2010 | 07:31 AM
fuzzy02CLS's Avatar
Interesting idea. Watch it. You may be impeding airflow using layers. I have similar stuff for a Home AC filter backup. It's a little thick.
Old Jun 9, 2010 | 11:55 AM
Add-dee's Avatar
Noobalicious
That maybe the case but considering what I took out. I bought it with 72k and I just changed them at 72,800. the ones I removed have been in sense the car was new... thats just SAD!
these are not HEPA-filters
besides if you compare the filter stuff I used to a new filter replacement you can see my will yield better CFM, I'm also not anal about tiny particulates...
Old Jun 9, 2010 | 11:58 AM
Add-dee's Avatar
Noobalicious
I should add if you cant tell, the filters i removed had cake in them and big a$$ leaves blocking them!
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
LeVeL
Oct 18, 2015 04:19 PM
scionxb3003
Sep 22, 2015 05:28 PM
