Help! OIL CHANGE!!!!!!!!
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
I have a 2001 Acura Type S with 221,000 miles on it. Which brand oil? How many quarts? Which weight?
Thinking Mobil 1!
Help me out people!!!!!!!
Thinking Mobil 1!
12 quarts shitty brand
dude seriously go to Kragens Napa Autozone whatever your part store is they usually have a specials on oil conv ranges from 13-20 synthetic ranges from 20-35 comes with 5 quarts or a jug and the filter, CL takes 4.5 or so, so you will have some left over.
Search is your friend.
First thing you should do is pour a 2 liter bottle of VANILLA coke before the oil. This will clean out the harmful deposits your engine probably picked up over all those miles. The engine should run much smoother after. It has to be VANILLA though, regular coke probably wont work as good.
Honda/Acura Technician
I have a 2003 CL-S with the J32A2 in it. I personally use a Honda oil filter, Honda oil pan plug crush washer, and either Castol or Pennzoil 5W-30 oil. I realize my oil cap says use 5W-20 but the 5W-30 is slightly thicker and will lead to better lubrication of engine parts, meaning longer engine life.
Unregistered Member
Honda oil filter isn't a great quality filter, but it obviously gets the job done. Oil brand isn't as important, as long as you use a well known name.
Whats up with RDX owners?
Yep. You have to want to learn going on there. If not, its easy to get lost among the plethora of informative posts.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
