halogen bulb replacement
Old Oct 20, 2007 | 11:25 AM
gnuts's Avatar
3.5 psi
I searched but didn't come across anything. My right (passenger) halo bulb is out and i'm not sure how to replace it. There's a cover over where the bulb would be that says "warning high voltage can kill...bla bla" I think the bulb is inside that. There's a weird shaped bolt holding the cover on. I'm not sure what to do without maybe getting shocked to death. Any help would be great. Thanks.
Old Oct 20, 2007 | 02:59 PM
fuzzy02CLS's Avatar
Are you talking about the high beam bulbs or the HID bulbs? The high beam bulb is very straight forward. Twist the locking ring & out comes the bulb.
The HID is more complex & it may not even be the bulb. You need to swap the bulbs to each side. There some good info out there on this process if you check out the FAQ & do a little searching.
Old Oct 22, 2007 | 10:39 AM
gnuts's Avatar
3.5 psi
I searched for hours and can't find anything. My daytime running light work fine. But when i turn my lights on (the ones that glow blue), only the left one goes on. I think those are the HID lights. It's a different bulb, the ones closest to the sides of the car. Under the hood there's a box that has a warning on it, and i can't even see the bulb. I really don't want to take it in to ask. I've changed bulbs on my old civic fine.....i know they just twist out, but i just can't get at the HID bulb. I'm going to check the fuse today, but i don't think that's it because the daytime lights go on fine. If there is a thread on it, can someone give it to me, because apparently i'm an idiot and can't find it.
Old Oct 22, 2007 | 11:35 AM
fuzzy02CLS's Avatar
Look at the FAQ please.
https://acurazine.com/forums/showthread.php?p=2539666
The HID's you can not just buy in an auto store. These are very different from regular lights.
oo7spy
Jun 19, 2023 12:48 AM
pplcrew
Jan 30, 2021 08:59 AM
acuraST
Sep 17, 2015 02:31 AM
brjones9
Sep 3, 2015 07:30 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
