Front end vibrates under braking
Old Aug 30, 2011 | 11:59 AM
a400tool's Avatar
7th Gear
Angry Front end vibrates under braking
2001 CL TL Type S 110K
Had vibration under braking. Not noticeable at low speeds. Changed brake pads and had rotors machined. No difference. Replaced rotors with better equipment, changed pads again. No difference. Noticed track rods were worn, replaced inner and outer rods and roll bar links. No difference. There does not appear to be any play in the balljoints. Am I missing something here?
Any help greatly appreciated
Old Aug 30, 2011 | 12:22 PM
swoosh's Avatar
takin care of Business in
did you bed the brakes in ?
Old Aug 30, 2011 | 12:24 PM
a400tool's Avatar
7th Gear
Yes, did that as well.
Old Aug 30, 2011 | 02:08 PM
StreetKA's Avatar
Get the wheels balanced it will fix it otherwise i would change rotors doesnt matter if they were machined or not sometimes they warp that bad so they loose the balance at all.
Old Aug 30, 2011 | 03:05 PM
a400tool's Avatar
7th Gear
I have replaced the rotors! Brand new, heavy duty! STILL vibrates!
Old Aug 30, 2011 | 03:23 PM
swoosh's Avatar
what setup do you have ?
how is your pedal feel ? does it sink in ?
Old Aug 30, 2011 | 04:23 PM
a400tool's Avatar
7th Gear
Pedal feel is good. No fade. All stock. Not lowered.
Old Aug 30, 2011 | 11:55 PM
celynka's Avatar
Sundance Gold in
I ve seen rust buildup on the hub - right between rotor and hub- mess up many brake jobs. It is a good idea to make hub surface shiny clean before you replace rotors
Old Aug 31, 2011 | 12:43 PM
a400tool's Avatar
7th Gear
Did that as well! Cleaned the hubs before installing the new rotors. Alignment and rebalance today. We'll see what happens.
Old Aug 31, 2011 | 12:47 PM
StreetKA's Avatar
Thats weird. If that doesnt help it may be axles idk
Old Sep 3, 2011 | 03:53 PM
hotclick56's Avatar
2023 TLX
Bent alloy wheels?
You may have bent alloy wheels. I got 3 like that (out of roundness is what they called). My mechanic tried to balance them using weights & it lasted for 1.5 years. Now, I'm having the vibrations again. Will have to replace all 4 wheels & new tires soon.
Old Sep 3, 2011 | 04:16 PM
StreetKA's Avatar
its recommended to balance your wheels every 5k if you put new tires and then every 10-15k
Old Sep 3, 2011 | 04:38 PM
1sickaccord's Avatar
did the wheel balance and alignment help out today??
Old Sep 3, 2011 | 05:20 PM
swoosh's Avatar
bubble in the tire ?
Old Sep 5, 2011 | 10:08 PM
eneffex's Avatar
run out? to the rotors, wheels or tire
Old Sep 12, 2011 | 05:18 PM
civicdrivr's Avatar
Do you feel the shake in the steering wheel or elsewhere?
Old Sep 16, 2011 | 05:15 PM
a400tool's Avatar
7th Gear
Ended up being the rear brakes! New rotors and pads completely solved the problem!
Old Sep 16, 2011 | 07:02 PM
civicdrivr's Avatar
Thats where I was going with it. Usually if you feel it in the steering wheel its the front brakes, but if the whole car shakes, its the rear.
TLDude876
Dec 28, 2016 03:18 PM
nanos
Nov 12, 2015 08:41 PM
02tljj
Sep 11, 2015 12:37 PM
nishant11
Sep 2, 2015 10:34 AM
