Engine rattle after new Power Steering Pump and Hose?
Old Feb 25, 2022 | 11:22 PM
Ancovell's Avatar
5th Gear
I recently installed a new power steering pump, as well as pressure hose. I noticed that the pump is fairly noisy, there is a slight shudder that I can feel and hear coming from inside the cabin of the car- like a rattle.
My fluid levels are fine, I have no leak.
My transmission mount on that side is fairly old. Aside from that possibility, I'm not sure why the pump is noticeably louder than the one I removed. Any ideas?
Old Feb 26, 2022 | 07:24 AM
There may be air in the PS system that is causing your noise.
After the parts were replaced and the fluid reservoir was filled to the upper line, did you bleed the air from the system by turning the steering wheel, from lock to lock, several times while the engine was running?
npolite
1G TSX Problems & Fixes
Jan 7, 2021 02:43 PM
Vtbx
1G RDX (2007-2012)
Oct 24, 2016 10:07 AM
Nersh7
Sep 12, 2012 05:12 PM
jbacura
Oct 23, 2010 04:12 PM
ananse
Jun 4, 2006 12:55 PM
