Engine overheats..need help ASAP
Old Jun 8, 2008 | 06:15 PM
clman99's Avatar
Last week while driving back from work, I saw antifreez coming out of my hood. Took it to a shop the next day, they changed the thermostat, still same problem. There is no leak in the radiator. The antifreez is coming out of the white plastic container that holds the extra antifreez. I can see the presser it builds up in that plastic container. Do you guys have any clue about whats going on with my car? If you do, please let me know. I really appreciate your help. Thanks. By the way, its a 2001 regular Cl.
Old Jun 16, 2008 | 10:38 PM
celynka's Avatar
Sundance Gold in
Have your antifreeze tested for CO2. In realy bad case you can smell exhaust fumes in reservoir tank. What happens is the exhaust gets pushed through head gasket and creates air pockets in cooling system causing temperature going up and pressure build up that pushes out antifreeze to reservoir tank. This means BHG. Blown head gasket
Old Jun 17, 2008 | 07:53 AM
Zippee's Avatar
Is the car overheating-temp guage higer than it should be or are you just seeing coolant coming out of the over flow bottle?
Old Jun 18, 2008 | 03:25 PM
clman99's Avatar
thanks for the replies. Both my fans were bad. Changed the radiator fan, but couldnt find the condensor fan. I found one, but it costs $220. Any suggesions?
Old Jun 19, 2008 | 12:42 AM
504P_CLS's Avatar
How badly did the car overheat with both fans bad? You may have done some irreversable damage already.
Check for oil or CO2 in the white overflow container as previous post suggests. If so, the HG is gone.
Old Jun 20, 2008 | 03:17 PM
clman99's Avatar
it drove it around 20 mins like that. Is that too bad? And where can I get that CO2 test done?
Old Jul 4, 2008 | 06:53 AM
tokenblack85's Avatar
The same thing happened to me but it was only my main radiator fan. I was gonna pay for the whole assembly but I got away with just replacing the motor for the radiator fan. It came out a whole lot cheaper.
SidhuSaaB
May 30, 2020 12:40 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
joflewbyu2
Oct 8, 2015 11:16 AM
ROSSARONIE
Oct 2, 2015 11:46 AM
STL TL-S
Sep 23, 2015 08:52 PM
