Cruise Control Will Not Activate
Old Sep 17, 2024 | 05:14 PM
Anon320's Avatar
Hi, I am a new member. I am disabled and in a wheelchair so I cannot fix issues myself. I am hoping to be able to diagnose the problem so when I go to the dealer, mechanic, or Firestone, if it is an easy fix, I can tell them what is going on, so I don't get hosed. I can probably get a friend to help me identify the issue, if I can tell them what to look for.
I have a 2001 Acura CL Type S. I don't know when the problem started exactly, because I don't drive extremely frequently. My Cruise Control won't activate. The main switch lights up when I push the button, but when I try to set it, it doesn't activate and the green light on dashboard doesn't come on. Could it be a blown fuse? Within the last two months, I had to have the stop brake light switch replaced, because my brake lights would stay on even when I was not braking or the car was off. I had it fixed at a Firestone location. When they replaced the switch, could they have done something that would cause the cruise control not to activate? If so when I go back what should I tell them to look at and what possible solutions should I suggest? I am hoping to avoid the dealer due to costs. Thanks for any help.
Old Sep 26, 2024 | 09:31 AM
It could be the #4 stop&cruise switch assembly or it could be that the #5 pedal stopper pad has crumbled / deteriorated.
It is needed to actuate the stop&cruise switch assembly in conjunction with the #10 brake pedal assembly when pressed.
Pedal - 2001 Acura CL 2 Door SPORT KA 5AT (acurapartswarehouse.com)
Old Sep 27, 2024 | 05:38 AM
This is most likely
mbgoldman
Jan 29, 2022 05:18 PM
KR3J//
2G CL Problems & Fixes
Nov 20, 2014 01:37 AM
rnorady
Feb 9, 2014 05:01 PM
actenniskrazy
Oct 23, 2011 08:37 AM
Zenonk
Mar 14, 2008 10:26 AM
