Cruise Control Not working What's the fix?
Old May 26, 2016 | 04:32 PM
maxguitars's Avatar
I have a 2003 CL-S and the Cruise control just stopped working. The light comes on but does not hold the speed. I removed the engine cover too look at the TB and it looks/feels like there is a plastic piece that holds on the Cruise Control Wire. It appears to have broken off. Short of buying a new TB which seems insane, has anyone rigged up an effective fix?
Thanks in advance.
Old May 28, 2016 | 12:53 PM
revvhappy's Avatar
I had a similar issue with cruise turning itself off. Turned out to be an intermittent clutch switch on the pedal. When I hit bumps it jiggled it enough to break the circuit as if I'd pressed the clutch.
I know it won't solve you problem but might help others searching for CC issues.
Old May 28, 2016 | 02:10 PM
maxguitars's Avatar
No, it's the cruise control link cable where it connects to the throttle, it sits in a plastic cam to hold it in place but the plastic has worn. I could try to glue it in place. I don't want to have to replace the entire throttle body for a cheap piece of plastic.
Old May 28, 2016 | 04:03 PM
You can try to fix the plastic cam with epoxy or something if you have all the pieces.
The part number for the throttle body on the Auto CL-S and the Manual CL-S are the same; therefore, if you elect to give the fix a try and it fails you might be able to find a used replacement TB, relatively cheap compared to new $374.42, from a local salvage yard in your area via car-part.com. Search for the automatic first because they made more of them, otherwise
Old May 28, 2016 | 06:09 PM
revvhappy's Avatar
Is the cam removable from the TB? If so there are many CL/TLs in the junkyards around me in Atlanta.
cfli1688c1
4G TL Problems & Fixes
Mar 6, 2022 07:19 AM
RobbDizzle
Dec 1, 2017 01:32 PM
ek513
1G RDX (2007-2012)
Apr 8, 2016 11:56 AM
danperson1
Jan 26, 2016 03:33 PM
