Compressor and Condensor Fan Won't start????
Old Aug 19, 2011 | 09:21 AM
sbkring's Avatar
4th Gear
Okay, this is on a 03 CL. I replaced the compressor about a month ago and it started making noise. After diagnosing the issue I found that it was compressor. So I got a new one under the warranty.
So I replaced the compressor and condensor yesterday and once I got everything back together and vac the system out everything looked good. I then started the car and turned the AC on to charge the system. I noticed that the compressor did not engage nor the condensor fan OR radiator fan would start.
I have checked over and over all the connection and can't seem to find anything missing. I even tried hooking the old compressor back up to see if it would engage and it wouldn't. So I am at a loss at what the issue could be.
Any thoughts would be greatly appreicated.
Also isn't there a way to do a diagnositic from the control unit to see a trouble code? I tryed the "holding down off" and hit the "recirc" button 5 times within 10 secs. and that doesn't seem to work.
Please help!
Old Aug 19, 2011 | 01:50 PM
m733l's Avatar
if all plugs and wires are connected properly, i would check the fuses next. definitely sounds electrical.
Old Aug 19, 2011 | 03:23 PM
celynka's Avatar
Sundance Gold in
Did you actually start charging the system? You need to give some pressure for a pressure switch otherwise compressor wont start
Old Aug 22, 2011 | 08:13 AM
sbkring's Avatar
4th Gear
Ah ha, after doing some googling, you are correct, it was the pressure switch holding everything out. I just jumpered it for a short period of time until I had enough pressure on the low side to meet the demand.
Thanks for the help.
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
obert
Dec 14, 2015 11:36 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
