Coin Box Removal
Old Sep 16, 2006 | 01:50 AM
R3d3mption's Avatar
Coin Box Removal
so yea...just the other day, i was cleaning out my car, and i noticed the coin box was loaded with change and it was looking sorta ugly so i emptied out the box, and to my surprise when i tried to close it, its jammed, i'm guessing since it was so full a bunch of coins somehow slipped behind it and is whats causing the jammage. I've looked all over and in the manual and everything and can't seem to find a way to take it out with out actually just tearing the whole thing out and probably destroying something...so if anyone has actually done it...could you please explain? Alright thanks for the help, pix if you got some!!!
Old Sep 19, 2006 | 01:11 AM
R3d3mption's Avatar
/bump
Old Sep 19, 2006 | 04:36 AM
CL'er 1st & 2nd Gen's's Avatar
Acura loyal for 93mo/109k
Try a couple good wacks to the side of the center console. See if that pays off.
Old Sep 19, 2006 | 12:01 PM
Stealth CL's Avatar
proffesion...axle breaker
yeah some whacks might work? thats the most useless thing on the car, not an ashtray/ nor a coin holder...wtf
Old Sep 20, 2006 | 07:25 PM
GreenMonster's Avatar
If you poke around the A/V forum, I'm sure you'll find something there...
Here's a pdf that shows what's involved getting the stock radio out:
http://www.skyeflye.com/acura_cls/In...01-2003_CL.pdf
Old Sep 27, 2006 | 09:49 AM
PhilB81's Avatar
Yup, getting to that is a bigger pain in the *** than you'd think.
I mean, if you're doing a head unit install, you can justify the amount of work, but for a stupid wannabe ashtray, I think it's a little excessive.
Good luck
Old Sep 30, 2006 | 02:45 PM
stjohn67's Avatar
stjohn67
It's easier to pull out the cover (emission connector) under the coin tray. It pops out and it'll pop back in there you'll see or hear the coins fall out. It's located under the tray and to the front. My 2 cents.
Old Oct 6, 2006 | 09:59 PM
BigLizard's Avatar
Moderator Alumnus
I threw that away when I bought the car. When bigger and better things come my way, I'm thinking of installing gauges there so they can be hidden . Besides, I don't ever use the drinking hold area at all anyways.
Old Oct 23, 2009 | 06:01 PM
jst2be's Avatar
3rd Gear
I just posted a similar post, Did you ever resolve this issue? I have the same problem.
Old Jan 3, 2024 | 05:19 PM
YVRCLR's Avatar
15 year old re-boot but nothing above was any help as I don't belong to the give-it-wack school.
OBD access pops off easily as it was designed to do. Anyone know anything about removing the tray.
The coins are being held firmly in place by the tray so to fix the nuisance it needs to come out.
Old Jan 3, 2024 | 07:09 PM
The below Helms instruction gives you an idea as to what is involved & appears to deliver the removal of your coinbox prize (red arrow) out of the car so you can examine it.
Though I suspect, along the way, you may find an easier method and not quite have to remove all shown below???
Good Luck!
Old Jan 4, 2024 | 10:17 PM
YVRCLR's Avatar
Appreciate the detailed schematic but that is way above my pay grade.
I'll learn to live with the nuisance.
Old Jan 6, 2024 | 12:54 PM
...that is way above my pay grade.
Understood.
dailo
May 15, 2005 10:12 PM
HondaOnly
Dec 5, 2004 05:17 PM
nick97
May 22, 2004 11:55 AM
voltech
Mar 17, 2002 12:35 AM
