Clutch Masters setup wont work in my car
Hey guys i got an 03 cl typeS 6speed M/T and i put in a Clutch Masters FX300 clutch kit with flywheel and it set off my check eng. light. Any body have this setup or know what the problem may be? If not then im just going to go with the comptech set. And yes the kit was installed right but the flywheel dose not look like its right for my car but clutch masters said that it is. can any ome help me?
03 Boosted CLS
I've had the CM FX300 in my car for a month now and just got to 650 miles with no problem. The shop who installed the clutch with the flywheel said the same thing that the flywheel looked different but that's because our stock flywheel is dual mass also it was a slight bit bigger but they checked and said it didnt seem to matter. The only thing i see that is different is the cranking noise when the car is starting. Other then that normal harder pedal and different engagement point. Like fuzzy said (and he knows best) i would pull a code. oh yeah what do you have done to your car too that you needed a stage 3 clutch?
Sundance Gold in
Some electric circuit was messed up, while tranny was taken out. There are no sensors involved with the clutch. Go back to your mechanic and have them fix it!
03 Boosted CLS
ok well get me the code starts with a "P" followed by some numbers. autozone can pull it for free. also from reading the service manual when they removed the transmission to get to the clutch they had to removed the crank position sensor B connector. so that might be something to check out because there is a ground cable there too.
Are you the CM fx300 in your car right now with the CM flywheel? What do you have done to your car? I want to supercharge it but everyone said that its a wast of money $4gs is a lot for only 60hp I would love to go turbo but that's any where from 6 - 8Gs can't do it well not this year any ways or the next lol
03 Boosted CLS
yes i have the CM fx300 + light flywheel in my car. had to upgrade because my Cl-S is turbo charged. the only supercharged cl i have been in was an auto so i dont know how it would compare to my 6speed. there is a turbo kit for sale on the black market but i dont know much about that kit.
Whats up with RDX owners?
+1 on the shop screwing up on the reinstallation.
Hey how much did your turbo kit run you and how much more power did you gain? Also could find out some more info on the turbo kit I NEED BOOST!!! Lol
03 Boosted CLS
https://acurazine.com/forums/car-parts-sale-361/%2A%2A%2A%2A%2Aacura-cl-complete-turbo-kit-%2A%2A%2A%2A%2A-719671/ this is a turbo setup for sale i dont believe you will be able to find a setup like mine becuase only 2 were built i have one and thinjim had the other but i dont know who he sold it to. It put down 355whp/308wtq on a dynojet @ ~7psi. (<--- previous owner ) im gonna go dyno it this summer when i get done with all the rest of the stuff. its nice as hell tho
