check engine light
Old Apr 23, 2007 | 10:15 AM
tummi's Avatar
04 TL w/navi
check engine light
hey guys, i just bought a 03 cl-s 6spd like a month ago, and the check engine light came on so i went to autozone and they said the spark plugs were mis-firing so i replaced all of them now, 5 days later the new spark plugs are mis-firing as well, any idea why? NEEEEEDDDD HELP!!!!! is it the wires? i ddint race or redline or drive it horribly i think its the wires but if anybody knows what it could be, can you tell me what it is, how to fix it, how much to fix it, and where can i get the parts at please
thanks in advance
tummi
Old Apr 23, 2007 | 10:36 AM
tummi's Avatar
04 TL w/navi
O YEAH, another problem is while im driving my ABS light comes on and off sometimes, and it is always on when i turn on car but while i drive for a good 10 min it turns off any idea how to fix that and the CEL as well please? anyone!?!?!?!?
Old Apr 23, 2007 | 11:44 AM
NSXNEXT's Avatar
Have Autozone tell you what the code is (the number that the scan tool reads). I have a tough time believing what someone from AutoZone tells you.
Old Apr 23, 2007 | 11:56 AM
fuzzy02CLS's Avatar
Yeah get the actual codes. We can go from there. There are no wires on the CL. It's coil on plug. So there's an ignition coil on each spark plug. It is possible that 1 or more of them may have gone bad. But that is rare.
Old Apr 23, 2007 | 06:29 PM
tummi's Avatar
04 TL w/navi
autozone said the codes were p0300 - p0306 which is the misfiring of all 6 spark plugs which i got last week as well i read from another thread posted about the similar problem and he had to do a valve adjustment, think that would work? or do i gotta replace the coils on plug another hting is my vtec actuator thingy makes a noise when i start my battery, think that could be the problem? or totally different?
Old Apr 24, 2007 | 09:24 AM
nbennettksu's Avatar
i heart latin chicks
Yea I mine read the same thing last week, I had 4 codes on mine (random misfires), checked all the connections and everything was fine...2 days later the CHK engine light went off....
Old Apr 24, 2007 | 08:04 PM
tummi's Avatar
04 TL w/navi
yeah lucky you.. mine is still on hoping it will just randomly turn off but whats the chance of that nobody has any ideas how to fix this and what the problem can do? man everybody helps everybody else but not me thats not cool
Old Apr 24, 2007 | 08:12 PM
I had the same problems as you, take all your spark plugs out, make sure all the connections are good, give them a good cleaning and you should be fine...
Old Apr 25, 2007 | 04:14 PM
cmhall's Avatar
9th Gear
Check your antifreeze level
Same thing happened to me. I called the service dept of the Acura dealer and asked them to guess what it may be. They said if the anitfreeze goes low there is a valve that does not work.
I topped off the antifreeze. Filled the reserve tank. Disconnected and reconnected the batttery (that resets the computer) and the problem went away. Has been gone for 2 days. I was looking at this site and remembered your question.
Hope this helps.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
