CD Player Problem
Old Sep 10, 2005 | 01:01 PM
lxe125's Avatar
CD Player Problem
I bought a used 2001 CL. When I load a cd into the player I get a ErEO error code. Could someone tell me what the problem may be. Thanks
Old Sep 10, 2005 | 11:12 PM
ANDY03CL-S's Avatar
"It's sexy time!" (borat)
The same thing happened to my 2001 CL it is just jammed or something i took mine to a dealer and they just took it out and replaced the whole unit. I also had CD's in the old one and they would not eject. They had to RTV that one and wait for the factory to take it apart and send my CD's back it took about 2 months to get them back
Old Sep 11, 2005 | 08:50 AM
lxe125's Avatar
cd problem
I don't think there are any stuck cd's in the unit. I can load cd's but get the error message when one tries to play.
Old Sep 11, 2005 | 02:52 PM
ANDY03CL-S's Avatar
oh okay when you load CD's in can you also eject them? Because i couldnt. It sounds like they just arent reading them correctly.
Old Sep 11, 2005 | 04:59 PM
lxe125's Avatar
cd problems
It gives the error message then automatically ejects the cd (if you only load one). If you continue to load cd's it will take them, then give the error message then eject. You can eject all of the cd's you load.
Old Feb 6, 2007 | 06:31 PM
cottoi's Avatar
YOMISMO
SO.... i AM NOT ALONE?
I have a 2003 3.2 TL doing the same thing. Did you ever find the solution? What does ErE0 means? I was playing burned CDs too and all of the sudden is coming out with the ErE0 error with the same malfunctions you described almost two years ago.
What up?
Old Feb 7, 2007 | 11:44 AM
notorious7182010's Avatar
Seton Hall Pirate
yah certain cds that i burn wont play. instead an error sign comes up. that has never happenned to me tho with a cd i bought. and usually my burned cds play too. try using a different or more quality blank cds when you burn music
Old Mar 1, 2007 | 10:39 PM
TOPHER33884's Avatar
Well, I have an 01'-03 BOSE 6-disc indash for sale CHEAP! LOL
Old Mar 2, 2007 | 03:18 PM
cottoi's Avatar
YOMISMO
03 Acura Tl Cd Changer
How Cheap?
Old Mar 13, 2007 | 01:45 AM
jyourg's Avatar
CD Changer Issue
Got a 01' Cl Type S with EE-E1 message on cd changer...looking for a replacement but most likely getting a different head unit. Let me know how cheap you have that cd changer for and in what condition its in
Old Mar 31, 2007 | 11:34 PM
celynka's Avatar
Sundance Gold in
you can get them for 150 on ebay. i fixed couple of units already and problem lays in very fragile cd tray system - trays jump off tracks or get misaligned
Old Apr 6, 2007 | 01:03 PM
4ank's Avatar
I have a few problems with mine. I just eject, re-insert....
Old Apr 13, 2007 | 05:57 PM
bleueyedblonde's Avatar
I'm having the similar problem with my CL and dont know how to make the CD changer work. I got an emailed offer from a guy on ebay stripping a damaged CL for parts and he wanted $300 for the stereo. Other than that, I havent been able to find ANY stereos, especially for $150!
Old Apr 14, 2007 | 06:16 PM
CLConcept117's Avatar
5th Gear
It can very possibly be that the lens need cleaning inside the deck. Go to a local cd store and buy a lens cleaner. insert in in the deck n problem should be fixed. it worked for me!
Old May 6, 2007 | 10:36 AM
kevsCLtypeS's Avatar
same thing
can someone tell me how to fix my cd player.. i sometimes change my cds and when i load a cd it just comes out.. also sometimes it will say ERR... i have to hit the side of it to make it work sometimes...
help...????
Old Aug 30, 2007 | 01:28 PM
darladoon's Avatar
i can't even eject my CDs once they are are inserted.
anyone know the problem here? will i have to call the dealer?
i have a 2001 3.2 CL-S
Old Sep 20, 2007 | 03:04 PM
dankness's Avatar
sometimes i have cd's get stuck when ejecting from the bose cd player. i have figured out that if you use something very slim, like a drivers license and you wedge it in between the CD and the mouth of the player and push cd up or down or both, it will free up and come out, or go all the way in. the key is realizing its happening and reacting to it before the error code.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
