A/C no longer cold
Old Jul 26, 2010 | 01:23 AM
briancl's Avatar
A/C no longer cold
My car is an 01. The A/C is no longer blowing cold air. Is this the A/C broken or do i just need to get the freon recharged? How much should this run?
Old Jul 26, 2010 | 01:25 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Brian, you might be able to fix it by going to the auto parts store and picking up some R134a refrigerant. This shouldn't be too pricey.
Old Jul 26, 2010 | 02:07 AM
YeuEmMaiMai's Avatar
after you find and fix the leak
Old Jul 29, 2010 | 11:17 AM
OperationDarkie's Avatar
Ultra Negro
if he has one, he might just need to recharge it.
Old Jul 29, 2010 | 07:23 PM
obviously it has a leak and he really should take the time to check it. After 9+ years i would not be suprised if a seal is compromised......
Old Aug 24, 2010 | 01:13 PM
bluedc2's Avatar
compressor?
Old Aug 30, 2010 | 12:57 PM
PANAMARED's Avatar
first check pressure, if it is low, gas definitely leaked. You can check for leaks with a color additive in the R134 or with a scanner. If pressure is ok there might be an electrical problem, check fuses, relay, ground connection
Old Sep 13, 2010 | 12:22 PM
derosee's Avatar
Where's the low-pressure port located on a CL? Are they color coded and of different size?
Old Sep 15, 2010 | 08:03 PM
Aquaholic21's Avatar
7th Gear
I have to recharge mine with 1 can per year...so I've got a 1 can/yr leak. Way cheaper to refill than fix.
Old Sep 16, 2010 | 11:06 AM
civicdrivr's Avatar
But horrible for the environment and could escalate into more issues. If it runs entirely dry and you let moisture into the system, you'll be replacing EVERYTHING.
If you found the leak, replace the pipe. Most of the pipes are under $50 anyway.
Biggie_B
May 27, 2025 05:51 PM
Jul 16, 2017 07:33 AM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
jmaxima03
Sep 27, 2015 10:22 AM
