broke bolt
Old Jun 18, 2010 | 03:31 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
broke bolt
Riped apart everything for p2r thermo upgrade and broke a TB bolt in the manifold.
I assume using 3 bolts would create a leak or will it ?
I thinking I'm going to drill it out if not.
Has anyone now/before had only 3 TB bolts and no leak ?
Old Jun 18, 2010 | 04:49 PM
Jacobpockros's Avatar
I think you should make your own Build thread and post all these questions in there rather than make a new thread every other day
Also, I would answer your question but i do not have an answer for it
Old Jun 18, 2010 | 05:15 PM
So why say anything ?
It's all together now and it seams to be fine idling.
I have not taking it for a ride yet but,there's no flucuating rpm's.
And while it was apart the whole intake and TB was cleaned again.
Old Jun 18, 2010 | 05:18 PM
I am saying this because it reduces clutter. I myself have my own build thread that i use to post all my questions in.
If i were you i would do it right and get a new bolt to replace the broken one
Old Jun 18, 2010 | 07:03 PM
civicdrivr's Avatar
Do you have any threads visible? If you can, lock two nuts onto the bolt and and unscrew it from the manifold.
Old Jun 18, 2010 | 07:15 PM
I did do that thats why it snapped .
It came all the way to the threds are just barely sticking out the back.
A couple more turns and it would've been all good.
Old Jun 18, 2010 | 07:44 PM
BigLizard's Avatar
Moderator Alumnus
One bolt isn't going to hurt. I did this on accident to my ol' cl. I didn't fix it till miles later. Never had any leaks.
Old Jun 18, 2010 | 08:35 PM
nspec_ya4's Avatar
Regional Coordinator (Texas)
use a chizle and a hammer and spin it out.
Old Jun 18, 2010 | 09:49 PM
SPoolinspOON's Avatar
OG 3.x^7 rawr
cut a slot and use a flathead
Old Jun 18, 2010 | 09:51 PM
fsttyms1's Avatar
Being on the TB i would replace it. If it starts to leak you are going to have serious RPM issues.
Old Jun 19, 2010 | 01:39 PM
aznboi2424's Avatar
i did this to one of the manifold bolts on the engine. luckily when I took off the mani, i had half an inch of thread so I screwed it out with locking pliars. but i bought an extractor kit just incase i needed to take it out that way
Old Jun 19, 2010 | 04:28 PM
assclown's Avatar
2000 acura tl FPR
i over torqued a bolt when installing my pressure plate and broke the head off it. so now i have threads stuck in my flywheel. i plan on using an "easy out" to get it out. just havent had time to deal with it.
tsx_boy
Dec 13, 2019 08:33 PM
polish_pat
Sep 30, 2015 12:22 PM
juanrl
Sep 29, 2015 03:25 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
