brake light is staying on
Just in the morning my emergency brake light in the dash will stay lit up even though the brake is off I looked in the manual and it could mean I need more fluid or new pads but im wondering why its only doing it in the morning. It has been happening in the past couple of days
If your pads are worn, espically all the way around, your fluid level will be down. Or, you could quite possibly have a leak. see any spots on the ground? reduced braking performance? I wouldnt drive 1 foot without fixing.
OG 3.x^7 rawr
If your fluid is low and you haven't added any, which you shouldn't because that light comes on when the float goes to a certain point in the resivour. Means that your brakes need attention, either pads or its leaking somewhere. It's somewhat comman sometimes for the float to get stuck. If the fluid is full, check the float. If its low, check to see if your pads are low if you know how to. Take it to a shop if you don't know what your doing. It's your BRAKES! you don't want anything to happen is something need to be replaced.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
