brake light is staying on
Old May 14, 2009 | 07:04 PM
2Fast4you's Avatar
Just in the morning my emergency brake light in the dash will stay lit up even though the brake is off I looked in the manual and it could mean I need more fluid or new pads but im wondering why its only doing it in the morning. It has been happening in the past couple of days
Old May 14, 2009 | 07:06 PM
DarkSithCL's Avatar
Be Strong AND Courageous!
...have u checked ur pads or fluid? I would not go another day without checking those out!
Old May 14, 2009 | 08:29 PM
SPoolinspOON's Avatar
OG 3.x^7 rawr
Look at the brake fluid resivour. Make sure the foam doughnut isn't stuck for some reason.
Old May 14, 2009 | 08:31 PM
Rajca's Avatar
wham bam thank you ma'am
check the fluid and make sure its at the proper level, make sure the e brake goes down all the way and nothing is stopping it, also check your pads.
Old May 14, 2009 | 08:48 PM
m733l's Avatar
sounds like you just need to add fluid.
Old May 14, 2009 | 08:51 PM
2Fast4you's Avatar
why would I need to add fluid did it leak or something?
Old May 14, 2009 | 08:56 PM
camaroracer016's Avatar
If your pads are worn, espically all the way around, your fluid level will be down. Or, you could quite possibly have a leak. see any spots on the ground? reduced braking performance? I wouldnt drive 1 foot without fixing.
Old May 15, 2009 | 09:08 PM
o1s's Avatar
o1s
ehh mine does it when the float in the cap gets stuck.
Old May 15, 2009 | 11:47 PM
nf3d0149ab's Avatar
There was a period of time where that was happening to me...on and off.
I just opened the brake fluid cap and put it back on and it went away.
Maybe the float was messed up...
Old May 16, 2009 | 10:35 PM
VIPCLS's Avatar
P.
Mine did that an the culprit was i needed new brakes. After i had my brakes replaced and rotors resurfaced i was good to go. This might not be the case though.
Old May 17, 2009 | 01:29 AM
OG 3.x^7 rawr
If your fluid is low and you haven't added any, which you shouldn't because that light comes on when the float goes to a certain point in the resivour. Means that your brakes need attention, either pads or its leaking somewhere. It's somewhat comman sometimes for the float to get stuck. If the fluid is full, check the float. If its low, check to see if your pads are low if you know how to. Take it to a shop if you don't know what your doing. It's your BRAKES! you don't want anything to happen is something need to be replaced.
Old May 17, 2009 | 03:29 PM
2Fast4you's Avatar
thats what ended up happening checked the fluid and it was plenty high enough but it doesnt happen anymore
Old May 17, 2009 | 05:50 PM
nf3d0149ab's Avatar
Good to hear.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
