big problem with srs - help
Old Jan 28, 2007 | 08:36 AM
TGS's Avatar
TGS
5th Gear
Angry big problem with srs - help
ok where do i start. i have put 3 steering racks in a 01 cl non type s and i finilly got one that does not leak but the SRS light is on. I tried to reset it (5 times) but no luck. I have also notied the controls for cruses and radio do not work. Does anybody have a suggestion on what i can check before i spend $$$ at dealrip?
I read through post and they say there is a blue wire under glove box but i removed glove box and still can not find it.
Old Jan 28, 2007 | 03:24 PM
TGS's Avatar
TGS
5th Gear
bump help
Old Jan 28, 2007 | 07:40 PM
gaping46and2's Avatar
SOLD: 03 SSM CLS Auto
Should probably get the SRS code checked. Not much you can do. Sounds like some loose connections with the radio and cruise.
Old Jan 28, 2007 | 08:35 PM
GreenMonster's Avatar
This might help... https://acurazine.com/forums/showthread.php?t=179416
Old Feb 18, 2007 | 01:01 AM
celynka's Avatar
Sundance Gold in
well while you were replacing rack you probably repositioned steering by a turn or two and than ripped clock spring wireing inide steering column. thats why srs and all the controls are gone
Old Feb 25, 2007 | 12:50 PM
TGS's Avatar
TGS
5th Gear
It was clock spring thanks for your help
cycdaniel
Dec 17, 2019 10:58 AM
Aug 15, 2019 12:58 PM
mugen_kid
Nov 13, 2015 10:38 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
brandnewcolony
Sep 12, 2015 10:39 AM
