Accident severed some wires?
Old Jul 25, 2009 | 09:29 AM
plunix's Avatar
After an accident where I was hit between my fender and my door, my power windows and power mirrors stopped working. Sunroof works fine as well as all other electronics. Also, strangely enough, my passenger side door will only unlock electronically if my door is open all the way (as if some wire is really on its last thread down there, i guess).
Does this sound like theres a wiring harness in that area that needs to be replaced?
Old Jul 25, 2009 | 10:02 AM
Rajca's Avatar
wham bam thank you ma'am
First. Check the fuses. Locates on the drivers and passengers side at the ends of the dash board.
Their are wires that run from the driver door controls all have fuses then to go their specific location. But ur wires can also be cut which wouldn't blow a fuse. Check the rubber gromit that's between the door and the pillar for any cuts.
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
Froid
Sep 27, 2015 06:16 PM
