2G CL Fuel Pump Wiring?
So the fuel pump isn't kicking on after having my '03 CL sit for a few days. Not sure if its the fuel pump relay or the pump itself and I'd like to check for power at the fuel pump plug. Does anyone know the wiring diagram for it?
Maybe it will give you the info you need to figure the rest.
If the car bakes in the sun and the FP main relay is original to the car, that is also a likely suspect, as you probably already know from research.
https://acurazine.com/forums/2g-tl-p...-relay-931252/
lol, I remember having to contort myself, getting up under there to get at that bloody thing and to replace. Great time to check the 'pedal stops' also. Those little things can ruin your day fast.
01cl_blk
Jul 9, 2015 10:41 AM
rdx158
1G RDX Problems & Fixes
Jun 11, 2015 01:18 PM
rdx158
May 22, 2015 06:24 AM
StonedCL
Sep 3, 2009 06:46 PM
